It is currently Tue Nov 24, 2026 11:58 pm
 Post subject: How to make Gimp Splash Screen
PostPosted: Sat Feb 11, 2017 4:03 am  (#1)
Hi to all,
today i'll show you a new tutorial to customize Gimp, in particular i'll show you how to make and install a spash screen in Gimp!
You can find tutorial here: http://www.asganafer.it/gimp-splash-screen/ :gimp
I hope you like it! :paint
Asganafer
 Post subject: Re: How to make Gimp Splash Screen
PostPosted: Sat Feb 11, 2017 10:14 am  (#2)
As your tutorial is in Italian I have created a shorter English version.
Use or create a .png image.
Name your image gimp-splash and put in the following folder.
C:\Program Files\GIMP 2\share\gimp\2.0\images
PostPosted: Sat Feb 11, 2017 10:21 am  (#3)
Better to save into the user folder.
PostPosted: Sat Feb 11, 2017 11:54 am  (#4)
Image will not be found at startup.
PostPosted: Sat Feb 11, 2017 12:05 pm  (#5)
You have to have a folder called "splashes" under ...Users/Username/.gimp-2.8 (or whatever release you have), you put all your created images there.
Startup will choose randomly one of your splashes
PostPosted: Sat Feb 11, 2017 12:49 pm  (#6)
dinasset :bigthup
PostPosted: Sat Feb 11, 2017 4:49 pm  (#7)
Asganafer
Another well explained tutorial !
Your tutorial (How to make Gimp Splash Screen) has been translated from
Italian to English and is included in the enclosed PDF file.
The Images used in the tutorial are also included in the PDF file
or if desired can be downloaded from Asganafer.s website.
File comment: PDF file Translating Asgaanfer's Tutorial How to make Gimp Splash Screen
Gimp Splash Screen Tutorial.pdf [1.15 MiB]
Downloaded 486 times
PostPosted: Thu Feb 16, 2017 5:19 pm  (#8)
Gimp splash screen it can also be animated. :yes
This is a gimp-splash.gif file - but with a changed extension to gimp-splash.png (deception :oops: - but it works in Windows).
splashes.zip [237.84 KiB]
Downloaded 393 times
PostPosted: Sat Feb 18, 2017 6:11 pm  (#9)
Hackathon :hehe
PostPosted: Sun Feb 19, 2017 4:48 am  (#10)
Yes - it's just an attempt (but really works).
I forgot to add (for it is obvious) - I used to scroll
https://gimplearn.net/download/file.php?id=1215
Thanks Tim.
PostPosted: Thu Dec 14, 2017 9:28 am  (#11)
I would like to share some of my Splash Screens for GIMP 2.8
cron
