It is currently Fri Oct 09, 2026 11:24 pm
 Post subject: Bling! Glitter! Sparkle! Tutorial
PostPosted: Fri Apr 23, 2010 11:41 am  (#1)
GnuTux has written a script for bling text and you can get it here.
This tutorial is for when you want to use a pre-colored glitter file. There are some very pretty animated glitter tiles you can find on the Internet but they can't be applied using the Bling Text Script. All of these, you will need to change the color mode to RGB before filling in your new image. Image > Mode > RGB. Some you will need to unoptimize.
Small site, unusual glitter
Glitters Galore
Auburn Angel
A web search for glitter will find other sites with glitter tiles.
This is important. It will save you a lot of time. Get fencepost's script that semi-flattens and puts the animation speed settings in your layers.
File comment: Reuploaded Dec, 20 2024 by Wallace
anim-settings-semiflatten.scm [3.91 KiB]
Downloaded 76 times
  1. Open your glitter file and process. Check the layer names and if Combine shows up in any of them, Filters > Annimation > Unoptimize. You will have a new image. Close the original glitter file. In the copy of the glitter tile, Image > Mode > RGB.
  2. Open a new image, 500 x 300, and fill the Background layer with white.
    If you want a color for your text besides black, change the foreground color to what you want.
    Select your Text Tool.You can download the font I used. SF Slapstick Comic Bold font
    Size 135
    Horizontal spacing, 5.
  3. Type your text and use the Move Tool to manually center it.
    Right-click the text layer and choose Layer to Image Size.
    Change the name of the text layer by adding #1 to the end of the name - don't add a space.
    Duplicate the text layer until you have the same amount of layers as the amount of layers in your glitter file. My glitter file has three layers.
    Hide layers #2 and #3 by clicking the Eye next to each one.
  4. Select layer #1. Right-click and choose Alpha to Selection.
    Select > Shrink > 2.
    Select > To Path in case you lose your selection.
    Now you will begin filling your text with the sparkle pattern. This takes concentration so I suggest you do it when there will be no interruptions. First, save your image file as an xcf file so you can return to it later if you need to. I recommend doing Ctrl + S after each new step so you don't lose your work as you progress. There will be reminders in each of the next steps to do that.
  5. Select the bottom layer of your glitter file, Edit > Copy or Ctrl + C.
    Select the Bucket Fill Tool and tick Pattern Fill. Click the pattern image and browse for the top, left pattern which will be the one you copied to your clipboard. Be sure to tick Fill Whole Selection in the Bucket Fill Tool options.
  6. Select the #1 Layer of your text image and click in the image and the Bucket Fill Tool will fill it with the glitter layer color.
    Select the #2 Layer of your text image and turn on the visibility.
    Ctrl + S (Save).
  7. Select the glitter file, select the next layer up (2) and Ctrl + C to copy.
    Click the text image and the Bucket Fill tool will fill layer #2 text with the second layer of the glitter image.
    Select the #3 layer of your text image and turn on the visibility.
    Select the glitter file and select the next layer up (3) and Ctrl + C to Copy.
    Click the text image and the Bucket Fill tool will fill layer #3 with the third layer of the gitter image.
    Ctrl + S (Save).
    Continue the steps above if you have more than three layers.
  8. When you have finished, delete the white Background layer.
    Unselect.
    Animation > Playback and play your animation. If it looks good to you, crop it and then you need to semi-flatten the layers.
  9. Filters > Animation > Settings with semi-flatten. Most glitter animations run at 100ms and unless you have a large background image in your animation, you will want each frame replaced. The default color for semi-flattening is white but if you are going to display your image on a colored background you will want to semi-flatten with that color.
  10. Now it is time to save your animation.
    File > Save As.
    Name your file and put a .gif extension at the end of it: yourfilename.gif.
    The gif file export dialog will appear. Tick Save as animation.
  11. Fill in the the settings in the next dialog.
    Frame delay rate (100ms)
    The frame disposal setting (Replace).
    Since you have already specified those settings using the animation settings, it's not necessary to do it in the dialog but I had you do it so next time you save an animation you will know what those settings are for.
 Post subject: Re: Bling! Glitter! Sparkle! Tutorial
PostPosted: Fri Apr 23, 2010 12:33 pm  (#2)
Very nicely written tutorial "O". I have it all printed and ready to go.....
Edit: couldn't stay away so did it sooner rather than later.... :wh
Thank you "O" for the tutorial.... Excellent!!!
PostPosted: Fri Apr 23, 2010 2:50 pm  (#3)
:blingbling Very pretty Molly. Thank you for trying my tutorial!
PostPosted: Sat Apr 24, 2010 2:09 am  (#4)
Hardly slept for about two weeks so this one going on my ever growing list of tutorials to follow when my head is clearer. lol But it's also going on my, videos to make list. :mrgreen:
This is just the sort of thing the teenage girls on youtube will love to learn. :blingbling
PostPosted: Sun Jul 10, 2011 12:03 pm  (#5)
wow...glitters :) very easy to do...thank you Oregonian :bigthup
My Flickr
PostPosted: Sun Jul 10, 2011 12:39 pm  (#6)
I'm happy you like it. I like your results. You are welcome. Please feel free to call me, O. It's much easier to type. :mrgreen:
PostPosted: Sun Jul 10, 2011 9:45 pm  (#7)
My wife thought it was a nice effect: :mrgreen:
PostPosted: Mon Jul 11, 2011 2:47 am  (#8)
strBlinking.zip
This is a similar effect that I wrote before
Now adapted for GIMP-2.7
(also support 2.6, It will according to the gimp version to use different command)
This script requires a pattern and a gradient which are included in the zip file(for default option)
Copy these files to your local pattern and gradient folder in order to use this script.
The scripts will be located under Filters -> Script-Fu -> Logos -> strBlinking....
Thanks
Sorry for my poor English, I use Google Translate.
There may be something wrong, Please understand.
GIMP 2.10.38 rev1 portable+GAP+G'MIC+nufraw+Beautify+MathMap+...
PostPosted: Sat Aug 20, 2011 9:47 am  (#9)
I missed your post entirely, JamesH. I immediately fell in love with your sparkle pattern. The script is great!
I don't know if you have seen GnuTux's Bling Text Script. The two scripts are entirely different and both are dedicated to sparkling.
PostPosted: Sat Aug 20, 2011 12:28 pm  (#10)
@JamesH,
I have your sparkling text in my gimp 2.7 folder and it works. I can't get that same script to work in 2.6.
Question: Is there a way to delete all the Chinese txt in the menu drop down menu's because I think that is why I can't get the script to work. I think there must be some kind of conflict in the language of the scripts.
This is the script in the drop down but it doesn't work in 2.6 Image
This is the error message I get. Image
PostPosted: Sat Aug 20, 2011 8:15 pm  (#11)
thanks, glad that you like it.
@JamesH,
sorry, that the Chinese version only work for 2.7.
the English version link above should work both 2.6 and 2.7.
and here is the other English replace version
scripts(English).zip
PostPosted: Sat Aug 20, 2011 8:19 pm  (#12)
The Chinese version in gimp 2.6 is interfering with the English one and it doesn't show in the menu. Which scripts should be deleted to get rid of the Chinese version?
PostPosted: Sat Aug 20, 2011 10:09 pm  (#13)
sorry for use different file name.
strBlinking.scm is Chinese version
You could delete this one.
PostPosted: Sun Aug 21, 2011 1:37 am  (#14)
Thanks for this useful tutorial. I really appreciate it.
PostPosted: Sun Aug 21, 2011 12:59 pm  (#15)
thank you James, that worked.
PostPosted: Mon Aug 22, 2011 6:36 am  (#16)
they look great Molly huh!
PostPosted: Wed Jan 02, 2013 2:54 pm  (#17)
Would i have to make glitter on my GIMP 2.8 ???? not sure where to start
PostPosted: Wed Jan 02, 2013 3:15 pm  (#18)
No, you don't have to make the glitter, You can download them from several places. Is it text that you want to make glitter? or clip art?
I have enclosed one 3 part glitter pattern you can download and place them in your pattern folder.
Make some text, duplicate it twice and you will have 3 layers. Use the bucket tool and paint glitter one into your first text, (the bottom one). select your next layer and paint your glitter #2 on that layer, then your glitter#3 on the top layer.
Once you do that, you can go to filters > animation > playback and click the play button arrow. You should now see the glitter.
autumn-pink-glitter.7z [27.84 KiB]
Downloaded 290 times
 Post subject: Re: Bling! Glitter! Sparkle! Tutorial please help!!
PostPosted: Thu Apr 09, 2015 6:25 pm  (#19)
Please i have been doing this since last night and just can get it, video i can watch for this pls?.
PostPosted: Thu Apr 09, 2015 6:58 pm  (#20)
Did you go File > Export As: [Name] .gif and put a check mark the animation box.?
