It is currently Wed Nov 25, 2026 8:08 am
 Post subject: GIMP Patterns
PostPosted: Fri Jul 21, 2017 12:39 pm  (#1)
This is not a tutorial per se, but because I used text I put it here.
I put together all the patterns I could think of that are made in gimp. (Not all the ones in Fractal explorer - only one) Patterns that can be rendered on a transparent background.
I haven't stroked these so they may be a little hard to make out but I put a drop shadow on each.
These patterns can be used almost anywhere, not just in text.
With most you can choose your colours - some you cannot, but you can always use colorize after.
Some of the patterns in File>create>patterns are just that - Patterns that are created - usually a tile.
These can be added to your selections by either turning them into a pattern (Copy paste as a pattern) in the pattern dialogue and filling with a 'pattern' or superimposing on your selection and inverting the selection and cutting/deleting the extra. I did the latter.
Most in your filters will just fill the selection.
 Post subject: Re: Patterns
PostPosted: Fri Jul 21, 2017 12:45 pm  (#2)
:tyspin What a very useful work you have done Sallyanne. Thank you so much. Please, Where can I find Barcode Fractal ? Thanks a lot. :coolthup
PostPosted: Fri Jul 21, 2017 12:59 pm  (#3)
That's something I didn't think of putting on straight away.
"Barcode fractal label" and many other fractals can be found in the fractal explorer. Under filters - render - fractal explorer. Most of them can be found in there and a few patterns can be found in File-Create - pattern
Anyway I will go away and try and put a list explaining where all these can be found now.
PostPosted: Fri Jul 21, 2017 3:01 pm  (#4)
Thank you so much Sallyanne.
PostPosted: Fri Jul 21, 2017 6:29 pm  (#5)
Thanks Sallyanne, a great idea :clap , I've bookmarked this page for future reference
 Post subject: Re: GIMP Patterns
PostPosted: Sat Jul 22, 2017 3:59 pm  (#6)
Awesome reference and demo! Thank You!
My Sigs = My Photos
