It is currently Tue Nov 10, 2026 6:44 am
 Post subject: Colouring B&W photographs
PostPosted: Tue Dec 26, 2017 4:12 pm  (#1)
A tutorial showing the method I use to colour photographs.
david.
Edit: small addition to the tutorial to explain how feathering produces smooth transition between colours.
photo_colouring.pdf [1.61 MiB]
Downloaded 477 times
Edit: PDF file was incomplete - now corrected. Also use of overlay mode changed to soft-light mode now they are different.
 Post subject: Re: Colouring B&W photographs - Part 2
PostPosted: Tue Dec 26, 2017 4:14 pm  (#2)
The second part of the tutorial.
david.
Edit: The complete file is now in #1 of this thread.
 Post subject: Re: Colouring B&W photographs - Part 1
PostPosted: Wed Dec 27, 2017 12:44 am  (#3)
Excellent tut, David. I saw it on GL and I told other users to have a look there; good it's now available also on GC.
PostPosted: Wed Dec 27, 2017 4:56 am  (#4)
You can also use this free web service to quickly color a B&W image using a computer algorithm with AI technology. It make quick work of it. https://colorize.dev.kaisou.misosi.ru/?lang=en
PostPosted: Wed Dec 27, 2017 8:45 am  (#5)
Cool tut David. I have only seen one other Gimp one which I used once. May try this next time.
Will have a look at that link now racer
PostPosted: Wed Dec 27, 2017 9:14 am  (#6)
Might save one a lot of work but no good if you want all of the photo colourized correctly
PostPosted: Wed Dec 27, 2017 9:35 am  (#7)
As far as i know, because of a bug, Overlay is still the same as Soft Light.
When it comes to grayscale images, isnt it much better to use the Color Layermode ?
From the manual:
Color mode uses the hue and saturation of the upper layer and the value of the lower layer to form the resulting image.
PostPosted: Wed Dec 27, 2017 10:43 am  (#8)
Konstantin,
Whilst the formula for overlay appears, at first sight, to contradict what is required, it gives acceptable results.
Using colour mode does not - try it and you will see!
david.
PostPosted: Wed Dec 27, 2017 11:05 am  (#9)
david wrote:
Konstantin,
david.
I did. In Overlay mode all the colours come out lighter as you pick them. How do you produce predictable results ?
You always have to guess what a colour will look like lightened.
But when you paint on transparent layers and put the grayscale base-image in 'Value Mode' on top, the colours stay the same.
PostPosted: Wed Dec 27, 2017 11:38 am  (#10)
Konstantin,
You have raised an interesting question and made me think!
In Overlay mode it is necessary to select a colour which will be correct towards the lighter parts of the image.
Having tried your suggestion of reversing the layers and using Value mode, a colour towards the darker part of the picture must be selected.
I will have to experiment further with your method to see which is easier and produces good results.
david.
PostPosted: Wed Dec 27, 2017 1:16 pm  (#11)
I have little need for this type of thing, but why not just use Normal mode on duplicate layer. Then use Color Mode on brush. Adjust opacity to suit.
Example:
color.mp4.zip [2.73 MiB]
Downloaded 769 times
PostPosted: Wed Dec 27, 2017 1:45 pm  (#12)
I learned a lot about selections from your tutorial David, thankyou. Here's my first quick try...
PostPosted: Thu Dec 28, 2017 2:37 pm  (#13)
@racer-x,
Thanks for the video. I think most people, when they first colour photographs, do it by free-hand painting on layers.
The method I used in the tutorial is that which works for me. It was written as the result of a request for help. Some of the techniques may also suggest other uses.
Of course there may be better ways of achieving the same result and I am always open to new ideas.
david.
PostPosted: Mon Jan 08, 2018 6:37 pm  (#14)
I have made a small update to the tutorial to explain how feathering produces a smooth transition between colours.
It is now split into parts 1a, 1b and 2 owing to uploading problems!
david.
PostPosted: Sat May 19, 2018 7:16 am  (#15)
Hi David,
Subtracting from the pre-created channels and performing the painting really gives a good result, interesting technique.
From the manual:
Luckily in this tutorial you were not asked to use color layer mode, since in Gimp 2.10 this mode disappeared.
Thanks for the tutorial!
PostPosted: Mon May 21, 2018 1:29 am  (#16)
@TicTac,
I am glad you found the tutorial useful. I hope it also explained the reasons for the technique so that it can be applied for other uses.
Having a set of channels - like the pieces of a jigsaw puzzle - allows adjustment to individual areas of an image with a smooth transition to adjacent areas.
Also, the channels are available to use as masks for adding localised effects.
david.
PostPosted: Sun Apr 21, 2019 3:08 am  (#17)
Found another tut to colour BW photos with Gimp and thought I'd give it a try. Using masks instead of selections
PostPosted: Sun Apr 21, 2019 5:40 am  (#18)
sallyanne,
Excellent result! Can you point us to the tutorial? I am always ready to find better ways of achieving good outcomes.
david.
PostPosted: Sun Apr 21, 2019 6:56 am  (#19)
david wrote:
sallyanne,
david.
Thank you David. I hope I can do more. This is it.
https://turbofuture.com/graphic-design- ... P-Tutorial
I read through it and I think got the idea of what to do, and then I did it..Took me a few days though.
I did do something extra that a friend told me awhile back - and that was, when I had finished colouring I put a copy of the black and white image above the photo in overlay mode to bring out the detail and also curves to taste.
PostPosted: Sun Apr 21, 2019 10:17 am  (#20)
Logged in just to tell you that your coloring of that photo is nothing short of spectacular. Very well done.
