It is currently Wed Sep 30, 2026 10:46 am
 Post subject: Magnifying Glass Effect
PostPosted: Sat Apr 24, 2010 10:56 am  (#1)
I wanted to make a pic with manifying glass efect in Gimp but I am not satisfied with my result much, does someone have some ideas and suggestion how to improve and make it more realistic?
File comment: Here is my result
File comment: Magnifying glass image
1206564626633666494sarxos_Magnifying_Glass.svg.hi.png [ 97.01 KiB | Viewed 28791 times ]
File comment: Trekking shoes sole image
 Post subject: Re: Magnifying Glass Effect
PostPosted: Sat Apr 24, 2010 11:04 am  (#2)
Hi nunulka! Nice to see you again. I saw your post over in UFSC and had something ready to post for you here.
What I did was use the Ellipse Selection Tool and fit it to the lens on the magnifying glass and cut then pasted and chose New Layer for the floating selection. Then I lowered the opacity of it to about 35. That's an amount that you can change as you wish.
I'm attaching the xcf file so you can look at the layers. I don't know what you did to magnify the other image so I'll leave that up to you.
magnify.xcf [805.45 KiB]
Downloaded 1152 times
PostPosted: Sat Apr 24, 2010 12:29 pm  (#3)
Thank you O, I used this tutorial http://tutorialblog.org/photoshop-magni ... -tutorial/ to make the effect, however without adittional effects. What I would prefer more is to add a bit spheric effect caused by the lens. Would you know to do it with the shoes sole?
File comment: Here is my work as xcf file
magnglasseffect.xcf [378.53 KiB]
Downloaded 775 times
PostPosted: Sat Apr 24, 2010 1:21 pm  (#4)
Yours is on the left, mine on the right. With your selection still on in the xcf file, I used Filters > Light and Shadow > Apply Lens. I set the Lens Refraction Index at 2 (experiment with the setting). Later note: In Gimp 2.8, Apply Lens has been moved to Filters > Distorts > Apply Lens
PostPosted: Sat Apr 24, 2010 5:33 pm  (#5)
very good guys....I didn't even know we have such a tool.... must give it a try.
PostPosted: Sun Apr 25, 2010 2:47 am  (#6)
Lol I looked for the lens effect before and couldn´t find it. :mrgreen: I did it as you suggested O. Then I copied a small part of the lens and set the opacity of it to about 17. The main part of the lens I set to about 20. Here is the result or do you have some more ideas to make it even better?
File comment: My Result
File comment: xcf file
magnglasseffect1.xcf [545.54 KiB]
Downloaded 761 times
PostPosted: Sun Apr 25, 2010 8:57 am  (#7)
I looked at the PhotoShop tutorial, would you rather the lens looked like the one in the PS tutorial? The shading all around? Yours looks good but I think the lens itself could be improved.
I'm going to experiment with the lens and see what I come up with. Going to try feathering the selection. Also do you want to keep the blue color of the lens or go to white?
PostPosted: Sun Apr 25, 2010 11:25 am  (#8)
Here is what I did.
  • I selected the glass area on the layer with the very long number.
    Grew the selection by 1
    Saved it as a path.
  • I made a new transparent layer below that long-number layer and named it lensfeather. Select that layer if it isn't.
    I feathered the selection 60, inverted the selection and filled it with blue.
    Unselected.
    Select > From Path
    Invert the selection and Delete.
All was done on the lensfeather layer. Try different amounts of feathering to see what you like best. I also put a color swatch in the attached xcf file for the blue color (b2c5d4). Also, the reflection you made, you might want to lighten it a little and add it back into the image.
magnglasseffect2.xcf [584.17 KiB]
Downloaded 725 times
PostPosted: Sun Apr 25, 2010 11:42 am  (#9)
Wow, it is very nice, O. Now it looks more realistic. I will try to do it too.
PostPosted: Sun Apr 25, 2010 12:13 pm  (#10)
An after thought here. I made a reflection using the paths tool and rounded the edges by dragging them just a little and filled the selection with blue (inset). Gaussian blurred it 5, and dragged it to where I wanted it and lowered the opacity. Learned that little trick from saulgoode. You can skip the blur if you like it better with sharp edges.
PostPosted: Sun Apr 25, 2010 12:35 pm  (#11)
Hi O, I am back. I did it as you suggested before. What do you think now?
Yours is nice, just maybe I would make the reflection a bit lighter. Just for trying. What do you think?
PostPosted: Sun Apr 25, 2010 12:38 pm  (#12)
I LIKE it. Looks nice. :clap
PostPosted: Sun Apr 25, 2010 12:44 pm  (#13)
Thanks to you, it looks much better now. Thanks for your help. I hope you will come on my birthday party in 3 days. :mrgreen:
PostPosted: Sun Apr 25, 2010 12:48 pm  (#14)
I sure will. I'll bring bells and whistles and make lots of noise. :noiseblower
PostPosted: Sun Apr 25, 2010 7:04 pm  (#15)
Cool Effect!
PostPosted: Tue Apr 27, 2010 10:52 am  (#16)
I like that effect...I bet Jolie could make a great little video tut, hee hee.
