It is currently Tue Nov 10, 2026 6:50 am
 Post subject: Create A Colourful Rosette Brush
PostPosted: Mon Jun 29, 2020 4:13 pm  (#1)
Erisian's Rosette Tutorial.pdf [2.42 MiB]
Downloaded 625 times
 Post subject: Re: Create A Colourful Rosette Brush
PostPosted: Mon Jun 29, 2020 7:25 pm  (#2)
Erisian wrote:
Thank you Erisian for creating this tutorial.
It's has been added to our tutorial index.
:jumpclap :jumpclap :jumpclap
PostPosted: Tue Jun 30, 2020 12:55 pm  (#3)
You're welcome Wallace. I will run through it myself because I was tired when I made it and I may have made some mistakes.
PostPosted: Tue Jun 30, 2020 1:45 pm  (#4)
:tyspin Thank you Erisian, your tutorial is very well explained. :bigthup
PostPosted: Wed Jul 01, 2020 1:05 am  (#5)
Erisian, thank you so much for your tutorial and your time to write and explain the process. I'll certainly do it. :tyspin :bigthup
PostPosted: Wed Jul 01, 2020 11:21 am  (#6)
A background (unpretentious :) ) from a brush made with your tutorial.
PostPosted: Wed Jul 01, 2020 11:52 am  (#7)
Thank you very much level_0 and Issabella. :)
That's a really cool background - you have given me some ideas...... ;)
If anybody who has downloaded this tutorial gets stuck at around point 9 with the selection. you need to invert the selection before doing the gradient fill. I will fix this in the PDF sometime. :oops:
PostPosted: Wed Jul 01, 2020 2:14 pm  (#8)
Erisian, Thanks again for your nice tutorial. I did my first Rosette and it has been so nice to do as you explained each step perfectly. :yes :paint :tyspin
PostPosted: Wed Jul 01, 2020 2:41 pm  (#9)
That's beautiful Issabella. :jumpclap :clap :coolthup I'm glad it was easy to understand. :)
PostPosted: Wed Jul 01, 2020 3:42 pm  (#10)
:wvy
with 2 others brushes
PostPosted: Wed Jul 01, 2020 4:09 pm  (#11)
Beautiful level_0. :jumpclap :clap :coolthup I love purple and magenta together. :luvstruck
