It is currently Tue Nov 10, 2026 6:50 am
 Post subject: Create a 'clipboard' brush & mandala with Symmetry Painting
PostPosted: Fri Jul 03, 2020 8:41 pm  (#1)
Regular Gimp Chatters know I am obsessed with mandalas. Erisian's original thread was based on using Symmetry Painting, which originally did not work for custom brushes. Now it does so here is a demo tutorial in which I create a custom brush using Ofnuts 'path inbetweener' plug-in and then a quick mandala using that brush.
PDF file tut is attached below along with a resources file including a starter xcf file with the layers and paths, the Ofnuts plug-in and the 'fade to fade' brush dynamic, the last two of which need to be unzipped and placed into your GiMP profiles.
Here is an image similar to that produced by the demo tutorial.
Resources.zip [1.69 MiB]
Downloaded 775 times
clipboard brush mandala.pdf [2.21 MiB]
Downloaded 782 times
 Post subject: Re: Create a 'clipboard' brush & mandala with Symmetry Painting
PostPosted: Fri Jul 03, 2020 9:21 pm  (#2)
Thanks OMG!
The tutorial has been added to our tutorial index.
PostPosted: Sat Jul 04, 2020 10:51 am  (#3)
OMG, Thank you so much for this tutorial you have explained so good. I've enjoyed doing it a lot. :yes :cool
PostPosted: Sat Jul 04, 2020 11:01 am  (#4)
very nice Issabella :)
PostPosted: Sat Jul 04, 2020 11:07 am  (#5)
Thank you OMG, your tutorial is great and I will try it first without looking at your xcf. ;)
Issabella, :clap
PostPosted: Sat Jul 04, 2020 11:17 am  (#6)
Thank you so much Sallyanne. :tyspin :)
Level, I didn't open OMG's file as the tutorial is clear and easy to follow. So I understand you want to do it since very start. :tyspin
OMG, Thank you again. :tyspin
PostPosted: Sat Jul 04, 2020 1:11 pm  (#7)
OMG :wvy
In my Gimp 2.10.14, I had put the ofn-path-inbetweener plugin (I think it's the last one, 10 KB) and yours is 8 KB.
I kept that of 10 KB but in step 5, I have an additional "output path" setting:
edit:
finally I put your plugin in. I'm going to start again :)
PostPosted: Sat Jul 04, 2020 2:37 pm  (#8)
first attempt
PostPosted: Sat Jul 04, 2020 3:22 pm  (#9)
Thanks OMG. Nicely presented tutorial. :bigthup
PostPosted: Sat Jul 04, 2020 4:25 pm  (#10)
Thanks for the tutorial, oldmangrupy.
I'm still learning new things in Gimp that I didn't know existed, symmetry painting for instance.
PostPosted: Sat Jul 04, 2020 5:14 pm  (#11)
Appreciate the tutorial OMG....as I am a newbie with paths, I was so happy to get a result, even though to me it looks more like a doily... :hehe ...
Great work everyone, some spectacular designs...
PostPosted: Sat Jul 04, 2020 11:41 pm  (#12)
Thanks to all respondents for your kind words.
Issabella and Ella Louise have highlighted in their submissions, something I forgot to point out and that is highlighting the finished mandala with additional effects, such as colour and texture. So I have posted a new one below, created as per the tutorial technique and which was originally the off white d8d8d8 colour as used in my tut, but to which I have applied a gradient, some GMIC filters and zoom blur to complete the image.
PostPosted: Sun Jul 05, 2020 4:21 am  (#13)
PostPosted: Sun Jul 05, 2020 5:32 pm  (#14)
I gave it a go and here is the result.
PostPosted: Sun Jul 05, 2020 11:46 pm  (#15)
Image Thanks OMG. It was a lot easier than it looks.
PostPosted: Mon Jul 06, 2020 12:12 am  (#16)
Beautiful results. Level, Wallace, Kimba :clap
OMG, thanks again for your tutorial. I'll do a new one, soon. :)
PostPosted: Mon Jul 06, 2020 11:14 pm  (#17)
Very clear tutorial OMG, thank you :tyspin. I didn't have the the 'fade to fade' brush dynamic so that's very useful (and the first new dynamic I've ever installed apart from making my own).
Thank you for the zoom blur tip, I will be using that again.
As level_0 mentioned there is a newer version of ofn-path-inbetweener available on Ofnuts' Gimp path tools sourceforge:
https://sourceforge.net/projects/gimp-p ... s/scripts/
Lovely results from everyone :jumpclap
Here is my try:
PostPosted: Tue Jul 07, 2020 1:45 am  (#18)
teapot, :wvy with zoom blur :bigthup
I have not yet tried with a thick texture like the last image of OMG.
PostPosted: Tue Jul 07, 2020 3:19 pm  (#19)
Most impressive teapot!...love the effect.... :clap ...
By any chance do you still have the link for the fade to fade dynamic?...I've not been able to find anything & am drawing a blank...
Many thanks...
PostPosted: Tue Jul 07, 2020 3:23 pm  (#20)
FlutteringBy - the Fade to Fade dynamic is contained in the Resources ZIP file in post #1
