It is currently Sun Oct 11, 2026 6:12 am
Post new topic Reply to topic  [ 70 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Vintage Lacy Picture Frame Tutorial
PostPosted: Wed May 05, 2010 6:54 am  (#1)
Vintage Lacy Picture Frame Tutorial.
This is what you can do with this tutorial and you can use your own imagination however you want to fill it.
- new layer (fill with white) default size
- new transparent layer (name it frame)
On the frame layer, select ellipse select tool
- Make an oval shape
- fill with pattern. I used (gold waffle) (see below for gold waffle pattern)
leave selected > select > shrink > 20 < cut > un-select
Decor > add bevel > 5 or whatever you choose, (un-click work on copy) > OK
New transparent layer (Name Lace)
Use guides and place one horizontal and one vertical midway between both directions like the image above.
foreground color black
Get the ring brushes
Brushes > Circle ring brush #4 size .98
On your lace layer, make a circle at top of frame, bottom and one at each side on the guides, then place a circle at each side of the center one. like image below
(There will be 3 circles on each side) Place another circle above each .98 circle which will be 4 size .98 circles on each side.
Change brush size to .78 and fill in evenly in between size .98 until it looks like this.
Note: I used red to show where all the size .78 circles go. You will be using black.
right click on lace layer > alpha to selection > bucket tool > click pattern fill > gold waffle > fill (Make sure you click the fill the whole selection in the pattern dialog.
leave selection on Decor > add bevel > 3 (or whatever you choose, > unclick work on copy > OK see image below.
Gold waffle2.pat [46.05 KiB]
Downloaded 719 times
 Post subject: Re: Vintage Lacy Picture Frame Tutorial
PostPosted: Wed May 05, 2010 7:52 am  (#2)
This is very nice work. When i saw the first image I thought 'Ok, pretty but she probably used a stock image and manipulated it' then I realized that you made it from completely scratch. Thanks
PostPosted: Wed May 05, 2010 8:11 am  (#3)
hope you enjoy and post your results.....
PostPosted: Wed May 05, 2010 9:21 am  (#4)
That is very cool. What a realistic cameo. :bugthumb
PostPosted: Wed May 05, 2010 9:38 am  (#5)
thanks GTux......
PostPosted: Wed May 05, 2010 10:04 am  (#6)
That's beautiful, Molly. The rings make me think of tatting. :wow
PostPosted: Wed May 05, 2010 1:45 pm  (#7)
Really beautiful. It looks like a real one. :coolthup
PostPosted: Wed May 05, 2010 2:25 pm  (#8)
Wow, I've never seen anyone create gimp with GIMP before. :wh
PostPosted: Wed May 05, 2010 2:30 pm  (#9)
wow saulgoode you just gave me some more ideas....chantilly lace looks interesting. thanx
PostPosted: Thu May 06, 2010 5:01 am  (#10)
I love it molly! :bigthup
I'm curious what more idea you have. :mrgreen:
PostPosted: Thu May 06, 2010 7:21 am  (#11)
Thank you Jolie, I would like to see you do one in your interpretation.....
PostPosted: Fri May 07, 2010 6:58 pm  (#12)
PostPosted: Fri May 07, 2010 7:17 pm  (#13)
That is very nice "O". Your frame is so nice and bright. I also like your cameo..... :cool
thanks for doing my tute :wh
PostPosted: Sat May 08, 2010 5:44 am  (#14)
I tried another more ornate frame...Image
PostPosted: Sat May 08, 2010 10:07 am  (#15)
Very pretty Molly!
I messed with my cameo, did color to alpha on it and removed the black in it. Putting it back over the background allowed that color to show through. I think it looks more like a "real" cameo that way.
PostPosted: Sat May 08, 2010 11:21 am  (#16)
Looks very nice....
PostPosted: Sat May 08, 2010 1:11 pm  (#17)
didn't do much with background/shadow...just wanted to see if I could get a dimentional look to the main part. I wasn't sure how to make it look "domed", rounded...any suggestions?
PostPosted: Sat May 08, 2010 2:28 pm  (#18)
that is so very nice 2-ton. I think it looks great.
I guess the only thing I would do different is add a couple of more rings to each side. Your background looks like pure silk.
Very nice.... thanx or doing my tutorial :keybdtype
PostPosted: Sat May 08, 2010 3:09 pm  (#19)
The pinkish part is supposed to look like cameo stone, lol. I think using bevel wasn't quite the right thing to do. It should look more hard and rounded, like the 'opal' brushes. Bevel gave it a sort of 'pleated' look, lol. Hmmm, wonder if I merged the white and pink together, then mapped it to something round, maybe it would have that round depth to it.
PostPosted: Sat May 08, 2010 3:49 pm  (#20)
Keep trying out different things and you might end up with a real master piece.
I guess that is what Gimp is all about cuz there are just so many tools we haven't even explored yet.
