It is currently Tue Nov 24, 2026 2:37 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2, 3  Next
 Post subject: Gold Dove Set
PostPosted: Thu May 06, 2010 7:24 am  (#1)
Gold Dove Set......
This is a jewelry set that I started out with a simple picture of a white dove and the use of a circle brush. You can use any kind of bird, animal object, text etc. and arrive with the same results.
Start wih a new layer, fill it with
white (I used the default size)
then cropped it when finished.
layer (transparent) name it dove
Scale it to size you prefer for
your pendant remembering to leave room for your chain
above it as showing in the gold and burgandy image above.
(Mine is 138.138)
Layer to image.
RT click on dove layer > alpha to selection
Click( lock alpha channel)
Gradient > Golden > draw across left to right with gradient
filters > Decor > add bevel > uncheck work on copy, set
thickness at 8 OK. select NONE
new transparent layer name it chain.
circles brushe's
paintbrush > circle brush #3
>size .78 > spacing 60.0 FG
color black >
draw chain as shown
gradient > golden > lock alpha channel > left to right with
gradient > Decor > add bevel >
uncheck work on copy, set thickness at 3 OK select none
Your Dove chain and pendant
are now done.
Earrings
Make a duplicate of your dove layer and name Earrings.
Move layer to top of stack >alpha to selection > resize
I made mine 52 H x 55W
Duplicate earring layer and
use your move tool to place them the way you want.
Merge earrings 2 down to earrings 1
alpha to selection > Decor > add bevel > uncheck work on
copy > set thickness to 3 OK
select NONE
Name it studs
FG = black
Use any circle brush and make a circle a little ways up from each dove
Follow same procedure for the Golden gradient as you used on the doves and chain. Don't forget to lock transparency. Then use bevel at about #3
New transparent layer
FG = black
take a very small brush and make a line down to join the circle with the dove.
follow gold directions same as above
VOILA all done.
Now let me see what you guys/gals can create using the same technique. They don't have to be doves. Just use whatever you desire or any background.
 Post subject: Re: Gold Dove Set
PostPosted: Thu May 06, 2010 12:01 pm  (#2)
I decided to go for silver. Here is my monkey with banana earrings. :-D
Nice tut, Molly! :paint
PostPosted: Thu May 06, 2010 12:27 pm  (#3)
Beautiful "O" I love it.
thanks for doing my tutorial.... love the monkey... :coolthup
PostPosted: Thu May 06, 2010 3:56 pm  (#4)
hahaha, the banana earrings are perfect!
I didnt experiment very much, prolly could have found better settings, but here is my jewelry!
PostPosted: Thu May 06, 2010 5:49 pm  (#5)
Wow 2-ton that is very good. Love your little musical notes earrings. Also, you did a very good job on your bevels. nice work
Thanks for doing my tute....
PostPosted: Thu May 06, 2010 7:22 pm  (#6)
I am not liking my chain very much. I don't think it looks real enough. Instead of setting the brush, I just stamped each link separately and I think they should have been like one pixel closer. Also, how to you get the chain to have more of a texture look to it?
PostPosted: Thu May 06, 2010 7:43 pm  (#7)
2-ton when you are putting your chains in you can set your spacing.
Click your brush then look down to the bottom of the window and you will see a spacing bar right "about the new brush", "duplicate", and "trash can".
Pull the slider over till you get it spaced the way you want then just brush your chain in.
When You get that finished, go to filters > add decor, bevel, and set it to about #3 for that chain... that will give it the textured and thicker look
post back if you have any probs....
PostPosted: Thu May 06, 2010 10:03 pm  (#8)
thanks for the hints, now it's a better chain, didn't do much with the star, it's just a brush, lol.
PostPosted: Fri May 07, 2010 4:13 am  (#9)
very nice 2-ton. I love the silver on pink....
PostPosted: Fri May 07, 2010 4:18 pm  (#10)
I really must learn how to make satiny and folded fabric!
PostPosted: Fri May 07, 2010 4:22 pm  (#11)
Fencepost has written a tuutorial for making satin texture here.
The satin behind mine is a satin swatch I found doing a Bing image search. Just put satin in the search, or if you're looking for a specific color like red, put in red satin.
http://www.bing.com/images
PostPosted: Sat May 08, 2010 8:16 am  (#12)
I've never been able to make a decent gold gradient, yours are excellent. Methinks I need to just plant myself in my chair and keep working at it until I get it right. First maybe I need to just really look at yours to see what colors are used and how they're arranged. Clearly yours are the standard I need work toward.
Thanks!
PostPosted: Sat May 08, 2010 8:28 am  (#13)
This is the golden gradient I use....
If you have any prob, don't be afraid to ask.
Golden.ggr [1.44 KiB]
Downloaded 360 times
PostPosted: Sat May 08, 2010 12:23 pm  (#14)
I just use the one that comes with gimp...but I change around where I click the start and end, until I get the effect I want.
PostPosted: Sat May 08, 2010 2:35 pm  (#15)
If you see the golden gradient and the one that came with Gimp side by side you will see a large difference. The golden is very much brighter....
PostPosted: Sat May 08, 2010 3:05 pm  (#16)
I've been using "golden"
PostPosted: Mon May 10, 2010 7:58 am  (#17)
Great tutorial molly! :jumpclap
PostPosted: Mon May 10, 2010 8:03 am  (#18)
thanks, nunulka :tyspin
That is gorgeous. You did a brilliant job. Looks like I might have to order that one from the jewelry store. :kpix
thank you for trying my tute.
PostPosted: Mon May 10, 2010 11:13 am  (#19)
really nice filigree on that set!
PostPosted: Tue May 11, 2010 3:21 pm  (#20)
Silver Parrots
