It is currently Mon Nov 30, 2026 8:59 am
 Post subject: sketched glass tut
PostPosted: Fri Aug 05, 2011 5:47 pm  (#1)
I'm looking for a sketched glass tutorial, i had one from gimptalk buts it's down at the moment
i did one a while ago but forgot some of the steps (getting old i guess)
it involved a quick sketch script and kward1979uk glass script
thanks
Andy
File comment: humming bird at the feeder
 Post subject: Re: sketched glass tut
PostPosted: Fri Aug 05, 2011 6:17 pm  (#2)
Here is GnuTux's Glass Effect Text Script
Here's a small example of using the script.
Also, here's kward's glass script. I can't find it in GIMP. It's supposed to be in <Image>/Filters/Kward1979uk/glass... but it doesn't show up and I expect because it's for gimp 2.4. I refreshed the scripts, and then closed and opened GIMP and it isn't there.
http://kward1979uk.deviantart.com/art/G ... 4-30316704
and kward's Sketch script, unfortunately it doesn't run in gimp2.6. Perhaps one of our script writers can update it.
http://kward1979uk.deviantart.com/art/s ... 4-30198844
A script writer probably needs to do an overhaul on both of them.
PostPosted: Fri Aug 05, 2011 6:59 pm  (#3)
I drew the tutorial off the gimptalk cache for ya:
etchedglass.pdf [666.49 KiB]
Downloaded 830 times
PostPosted: Fri Aug 05, 2011 7:05 pm  (#4)
Whoa! Thanks mahv. I have that tutorial stashed somewhere. The pdf is great to have.
PostPosted: Fri Aug 05, 2011 7:32 pm  (#5)
Whenever you want a tutorial off of GimpTalk and it's down, you just need the direct link to the tutorial (obviously you can't search it on GimpTalk if it's down, but...) most times tutorials will show on the search pages. If you get a search page that has no cache options, just type (only tested this on Google, btw)
"cache:" in front of the URL (minus the quotes).
Example: cache:http://theurltothetute.com/
PostPosted: Fri Aug 05, 2011 7:49 pm  (#6)
I do believe you can contact Rod as well
I'm back I think
PostPosted: Fri Aug 05, 2011 7:53 pm  (#7)
What does this mean or have to do with my comment?
Rephrasing my original question, as it may appear aggressive: Does Rod have the entire cache of GimpTalk or something? I was just giving a self-help tip to people who find GimpTalk down and still want to view the tutorial.
PostPosted: Fri Aug 05, 2011 8:02 pm  (#8)
Kward's Script-fu works for me O; going to post it here just in case somehow I got a different version (updated for 2.6). :)
glass.scm [3 KiB]
Downloaded 542 times
PostPosted: Fri Aug 05, 2011 8:07 pm  (#9)
Your script is different than mine, Lyle. I am testing the difference between the two.
Lyle, the script you submitted is the reworked original. Thanks for posting it.
PostPosted: Fri Aug 05, 2011 8:31 pm  (#10)
thanks mahvin that's the one i was looking for
kward script works in my gimp 2.6.11
PostPosted: Fri Aug 05, 2011 8:34 pm  (#11)
Forgot to include Kward's Sketch Script-fu too. What you need to do is delete the base layer and then apply the mask before running Kward's Glass Script-fu. Do this as a top layer to another base glass layer for better effect. :)
sketch_script_fu_now_2_6_by_kward1979uk.scm [2.51 KiB]
Downloaded 322 times
PostPosted: Fri Aug 05, 2011 9:25 pm  (#12)
Thanks for the updated scripts, Lyle. Cool!
PostPosted: Fri Aug 05, 2011 9:42 pm  (#13)
Don't thank me; not sure if it was RobA or Kward himself that fixed these Script-fus at GIMPTalk, but since they are down and I'm too lazy to use the wayback machine (or google cache for that matter), the answer is still in the air, but I'm just a poser/user (but don't call me a looser; lol) and not a programmer. lol
PostPosted: Mon Apr 15, 2013 7:31 am  (#14)
Another one I missed, very nice Lyle, I would like to see that one done with a very light Aqua BG. Thank you for the updated script. :paint
PostPosted: Mon Apr 15, 2013 3:52 pm  (#15)
I seem to have missed a few of these myself.
Thanks Lyle.
@ Mahvin and @ Willy (if you still read this forum).
I used to have all the GimpTalk tutorials on my machine, but that machine is now non existent as well as everything on it. lol
PostPosted: Tue Jun 09, 2015 12:05 pm  (#16)
:jumpclap
