It is currently Fri Oct 09, 2026 2:46 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: Lord of the Rings text tute
PostPosted: Sun Aug 28, 2011 4:26 pm  (#1)
This is a nice little script made by Fencepost for those who are interested. I made this image below with it.
Lord Of The Rings Script 2.6
Lord Of The Rings Script 2.2
ringbearer font
Open up a new transparent image...I used the default (640x400).
Type in your text using black foreground color.
filters > alpha to logo > Lord Of The Rings (I used dimpled setting)
I used 342772 color on the first one. then clicked OK.
Voila! your new Lord Of the Rings text.
The second one I changed the color to (# 3a596f) and used the Angular setting.
You can experiment with the settings yourself, there are no set rules on that.
On third one I changed the color to 5d2532 and used the Spherical setting
Hope you enjoyed this script by Fencepost.
Molly
FP-Lord of the rings.pdf [88.17 KiB]
Downloaded 538 times
 Post subject: Re: LORD of the RINGS text tute
PostPosted: Sun Aug 28, 2011 11:34 pm  (#2)
Thanks Molly! :)
PostPosted: Sat Dec 07, 2013 3:00 am  (#3)
I was looking for this script some time ago, but I forgot about it until now.
Thanks Molly for posting the links. :bigthup
PostPosted: Sat Dec 07, 2013 6:39 am  (#4)
just to remind that there is also a animated version (thanks to Graechan )
PostPosted: Sat Dec 07, 2013 9:00 am  (#5)
this is not a tutorial, its a how-to-use-a-script
the original tutorial is gone and thats a shame because that technique was real special
PostPosted: Sat Dec 07, 2013 12:04 pm  (#6)
which is a tutorial by definition!
PostPosted: Sat Dec 07, 2013 1:38 pm  (#7)
PostPosted: Sat Dec 07, 2013 2:52 pm  (#8)
I found a Lord of the Rings text tut here.
How to make a "Lord of the Rings" style text (Gimp)
PostPosted: Sat Dec 07, 2013 3:00 pm  (#9)
Thanks Odin, that is really cool the way this tutorial was hidden in a spoiler, I like that.
PostPosted: Sat Dec 07, 2013 3:17 pm  (#10)
I'll have to check out the script because it's been rumored I have a thing for animation! LOL Thank you Graechan for making it!
Well, I was able to recover my old tutorial images for this, and many others, but the LOTR written steps appear are gone forever. I want to thank Molly for her diligence over the years in trying to post my tutorials/scripts here in an effort to keep them alive. Unfortunately, I didn't back up all of my files and she wasn't able to get this one posted here before it disappeared. You're a gem, Molly, and I appreciate your efforts. :jumpclap :tyspin Not sure what health/salary benefits for being a GIMPchat moderator are, but management should consider doubling it for your great work! :rofl :rofl
Honestly don't know if the images will be of any use to anyone since GIMP has changed, but I told her I would rewrite the steps if she felt they would be beneficial. However, Odinbc's link to the other tutorial probably takes care of that anyway. Thanks for the link Odin. :hi5
I'm also providing Molly with links to all my other tutorial images in case there are any tutorials y'all would like posted here. The ones I'm really interested in having are my scripting ones....I can't remember how to write a script!!! LOL GIMPtalk has the steps, but not the images....I have the images, but not the text. Sounds like we have a match. :roll:
PostPosted: Sat Dec 07, 2013 3:25 pm  (#11)
lift them from Gimp Talk...
Thank you FP for the nice compliments. I remember back when you said you were busy and were going to take some time off to spend more time with your music. I asked you then if it was all right for me to post some of your tutorials here on GC and you said yes you would be honoured. Well, I am glad you are back and I am humbled by your post.
PostPosted: Sat Dec 07, 2013 3:26 pm  (#12)
Not many folks around here like tutorials within spoiler tags Molly.
A spoiler tag is mainly for adding punchlines for jokes and spoilers for movie and television show endings and stories. Not sure why that tag is even allowed in this forum really. Last time i used it here to hide a tutorial, i got bushwhacked by a few members. :lol
PostPosted: Sat Dec 07, 2013 3:38 pm  (#13)
I just liked it cuz it can save so much room. Do spoilers take up the same amount of bandwidth when they are closed?
PostPosted: Sat Dec 07, 2013 3:45 pm  (#14)
thats a different one
i posted a rewrite of the tutorial that was based on the script a few hours ago but removed it again, because sometimes this forum is doing my head in
will post it on my blog some other time
PostPosted: Sat Dec 07, 2013 3:54 pm  (#15)
Might as well, since your steps/images will using the most current version of gimp. :)
PostPosted: Sat Dec 07, 2013 4:07 pm  (#16)
dont think its any different
http://gimp-science-labs.blogspot.de/20 ... ffect.html
PostPosted: Sat Dec 07, 2013 9:16 pm  (#17)
I like seeing the examples in the different 'metal' colors! It gives a great perspective on colorizing results.
PostPosted: Sat Dec 07, 2013 9:36 pm  (#18)
I agree... ;)
PostPosted: Sat Dec 07, 2013 9:54 pm  (#19)
thats really just playing around with the sliders and not ideal if you have a very specific colour in mind
alternatively you could create a new layer in a colour you like and set the Mode to 'Colour' (or any other suitable Mode ('Hard Light' in the second example))
that has the advantage that you can play around with the Opacity and fine tune your result
PostPosted: Sat Dec 07, 2013 10:05 pm  (#20)
That is so sweet, well done Esp! :jumpclap
