It is currently Wed Sep 30, 2026 7:01 pm
 Post subject: Make your own Youtube Template!
PostPosted: Mon Jun 07, 2010 7:42 pm  (#1)
I couldn't find this on here and I figure it would help some people. This is a quick simple thing, not really classified as much.
Anyways, to make a youtube template, just use the measurements of:
Width=1800
Height=2100
If you are a partner you can also do the banner, something I have no idea on!
I am including my personal template for you all to look at, to preview your background before uploading.
Never mind I can't, the extension isn't permitted. Anyways if you want me to send you my blank template, just ask me and I will send VIA PM.
Hope this helps,
M3SH
 Post subject: Re: Make your own Youtube Template!
PostPosted: Mon Jun 07, 2010 10:00 pm  (#2)
Can you zip it and then attach it?
PostPosted: Tue Jun 08, 2010 7:10 am  (#3)
I just tried but it doesn't allow that extension, these are the ones it accepsts: swf, gif, jpg, jpeg, png, apng, bmp, tif, tiff
PostPosted: Tue Jun 08, 2010 7:18 am  (#4)
can you make a screen shot of it
PostPosted: Tue Jun 08, 2010 8:06 am  (#5)
Well, I could BUT it would be REALLY BIG and you wouldn't be able to remove the parts you need to remove.
PostPosted: Tue Jun 08, 2010 8:31 am  (#6)
When you zip a file and it doesn't like the name like a certain extension, it won't send. But, you can name it whatever you want then zip it with a different name. Did you try that. What is the name of the file and extension it has now?
PostPosted: Tue Jun 08, 2010 8:56 am  (#7)
You need to use Upload Attachment which is just below the text entry posting box. Scroll down from the text entry box and you will see Upload attachment.
There's a place to browse for your file then Add the file. You will need to wait for it to upload then you can submit the post.
PostPosted: Tue Jun 08, 2010 10:43 am  (#8)
This is what I have tried using: http://screensnapr.com/u/i/szo5qb.png
PostPosted: Tue Jun 08, 2010 11:05 am  (#9)
Members of Gimp Chat can upload and attach files directly into their posts in Gimp Chat because Gimp Chat has its own upload site.
Check this link. It tells you how to upload images into Gimp Chat and also how to attach files (zip files are included).
http://gimpchat.com/viewtopic.php?f=13&t=67
