It is currently Fri Oct 02, 2026 5:07 pm
 Post subject: Psychedelic text effect in Gimp
PostPosted: Fri Sep 23, 2011 6:07 pm  (#1)
I found this short and easy tutorial written by a person named Pappke.
You can find this tutorial on
http://www.gimpusers.de/tutorials/psychedelic-text
The only thing is that is written on german language (but with a little help from Google Translate you'll figure it out).
Anyway I hope you'll like it:)
1.) Open new image 1600x1200 px and fill it with white color.
2.) In your toolbox click on your paintbrush tool and choose ''sparks brush.Now set these settings:
Paintbrush mode: Normal ; Opacity: 100,0 ;
Brush: Sparks ; Scale: 1,70 ;
In brush dynamics :
a) In the pressure check Opacity
b) In the random check Opacity,Hardness;Size;Color
Check ''Use color from gradient'' (choose ''Tropical Colors'' gradient);
Lenght:100 px ;
Repeat : Triangular wave
3.) Click on your Text tool and for the font choose ''Sans'' with the size of 500 px.
4.) Write the text.
5.) Click the Alignment tool….then click on your text…now click on this two arrows to center your text.
6.) Again click on text tool and then on your text…Now press the ''Path from Text''button in the bottom of your toolbox window.
7.) Go to your path tab in your layer window dialog and turn on the eye.Now click twice so that the path became active.
8.) Create new transparent layer.
9.) Go to Edit – Stroke path and use these settings.
Click on ''Stroke with paintbrush'' ;
Check ''Emulate brush dynamics''
10.) Repeat step 9.
11.) Now go to path tab in your layer window and turn off the visibility (uncheck the eye).
12.) Also turn off the visibility for the text layer.
13.) Go to Colors – Curves and set the curves for the value like this:
14.) Go to Filters – Edge Detect – Edge and enter this:
Algorithm: Sobel ; Amount: 4,0-5,0 ; Smear
15.) Click on background layer and fill it with black color.
I hope this was understandable.
My Flickr
 Post subject: Re: Psychedelic text effect in Gimp
PostPosted: Fri Sep 23, 2011 6:10 pm  (#2)
Is that font some type of wire frame font?
Cool effect by the way.
PostPosted: Fri Sep 23, 2011 6:13 pm  (#3)
No Rod.This is ''Sans'' font.
My Flickr
PostPosted: Fri Sep 23, 2011 6:20 pm  (#4)
It almost looks as if the font has an inside dimension to me.Pretty neato. :)
PostPosted: Fri Sep 23, 2011 6:25 pm  (#5)
Very nice Ana. BTW, there is a place at the top to click translate if you want it in English
PostPosted: Fri Sep 23, 2011 6:32 pm  (#6)
I didn't saw it.
My Flickr
PostPosted: Fri Sep 23, 2011 10:57 pm  (#7)
Very understandable to me. :)
Gotta admit though i ws scared for a while there after the stroke twice effects.Didn't look too good until the edge filter was used on it. :bigthup
Nice tutorial and nice effect!
PostPosted: Fri Sep 23, 2011 11:09 pm  (#8)
Here is one with a ghost diagram PNG file as the selection lines. :)
I had to make the brush smaller of course - 10 pixels then 20 on the second stroke.
PostPosted: Sat Sep 24, 2011 4:18 am  (#9)
Wow Rod :)This is great...I like it ...and I'm glad that you like the tutorial :)
My Flickr
PostPosted: Sat Sep 24, 2011 5:09 am  (#10)
Very pretty Rod
