It is currently Mon Oct 05, 2026 2:38 am
 Post subject: Basic Tutorial For Removing A Frame Using A Layer Mask
PostPosted: Sat Oct 22, 2011 10:19 am  (#1)
Basic Tutorial For Removing A Frame Using Quick Mask
Once again I am using my favorite twins photo.
In this tutorial I want to remove the existing frame and replace it with something else.
- Open an image of your choice, it will be named background.
- Duplicate the layer :dupe Name the layer Duplicate
- ( I like to use a duplicate in order to preserve the original layer.)
Turn the eye off on the BG to make it invisible
- right click on Duplicate layer, add layer mask.
- When Layer mask dialog comes up, use default (white with full opacity)
- Set foreground color to black.
- Left click on mask to activate, (you will see a white square around the layer mask when selected.)
- Make a selection around your image, in this case I selected around the inner mat.
- fill selection with black, (you will end up with a transparent image
-CTRL-SHIFT to deactivate selection
- Colors > Invert (your image will be painted back in.)
- Still working on your layer mask > Image > Noise > Spread (I used 20-Horizontal 20-Vertical
When you have your image the way you like, add new layer :new , fill it will color of your choice. You can also use the color picker to select one of the colors in your image to use for a background, or use a gradient etc., then move the layer to the bottom of the stack.
Save as a XCF file if you want to go back to it or a png.
Sidenote:
Instead of using the noise filter, there is the wave, whirl and pinch, ripple, or even putting a different frame on it. experiment with different alternatives until you are happy with what you see.
There is always that famous Undo option (Ctrl-Z) until you get what you want.
I opted for a black frame to tie in the black in with the image
 Post subject: Re: Basic Tutorial For Removing A Frame Using A Layer Mask
PostPosted: Sat Oct 22, 2011 10:27 am  (#2)
Another nice tutorial, Molly. WTG!
PostPosted: Sat Oct 22, 2011 11:01 am  (#3)
thanx! :teeth
PostPosted: Sat Oct 22, 2011 11:24 am  (#4)
I like how the spread filter makes the edges appear to have frayed threads sticking out from the cloth texture (I may have to steal that idea someday).
PostPosted: Sat Oct 22, 2011 11:44 am  (#5)
Help yourself Saul :teeth
