It is currently Tue Oct 06, 2026 5:25 pm
 Post subject: Another Wire & Cable Tutorial
PostPosted: Tue Jan 03, 2012 7:07 pm  (#1)
After viewing Rod's great tut on making wires, I was reminded of another tutorial I saw someplace. I'll have to look for it again and I'll post it whenever I find it.
I'm also looking for another one at the moment cuz I used three different methods to make the pic below.
 Post subject: Re: Another Wire & Cable Tutorial
PostPosted: Tue Jan 03, 2012 7:28 pm  (#2)
Very nice Drac
PostPosted: Tue Jan 03, 2012 7:58 pm  (#3)
That turned out pretty good. :)
Nice job and thanks for sharing it.
PostPosted: Tue Jan 03, 2012 8:13 pm  (#4)
The conduit is especially lifelike!
PostPosted: Tue Jan 03, 2012 10:29 pm  (#5)
That top layer of armored cable (BX cable) looks really good.
I hope you find the tutorial - I'm interesting in seeing it.
PostPosted: Wed Jan 04, 2012 6:39 am  (#6)
Found it! Thanks for the comments guys.
http://thinkmoult.com/2010/09/27/the-gi ... -tutorial/
I think the tutorial was made in an earlier version of GIMP because of the way the lines were done to make the segments. The way I did the lines was Filters>Render>
Patterns>Grid and just set the vertical to 0 and adjusted the line spacing and line thickness. Made it really simple, otherwise a fairly easy tut to follow.
Yes, I was trying to make the cable look like MC cable but you are right. MC has a full sized ground wire and even BX has a small aluminum drain wire. I may have to make a couple of small changes to the pic. I was thinking that the composition could use something like some corroded metal gears here and there to give it more of an industrial feel.
I made a set of open circle brushes, some feathered on the inside, to stroke a path and just experimented to make the cable. Due to the multiplication effect of the circle brush, I got this really dark edge so to remove it, all I had to do was adjust the brush just a tad bigger than I needed and then do an alpha to selection/shrink/delete to make it look right.
Open Circle Brushes.7z [25.86 KiB]
Downloaded 499 times
