It is currently Tue Oct 06, 2026 12:41 am
 Post subject: Better Foil
PostPosted: Fri Jan 06, 2012 12:47 am  (#1)
I saw a two step mini tut over at Gimp Talk and was (you guessed it) experimenting again and came up with an entirely different look.
Step 1. Open a new image and select the gradient tool. Set the gradient tool mode to "difference".
Step 2. Start clicking around in all directions about 20 to 50 times or until you get a sort of uniform look but not too dense.
Step 3. Go to Filters>Map>Bump Map and use the settings below.
Not a lot of change in the image yet so I won't bother with a pic.
Step 4. Next is Filters>G'mic>Presets & Testing>Photocomix Smoothing and use these settings.
And you get something like this.
Step 5. Now Go to Filters>G'mic>Artistic>Watercolor and enter the settings shown here.
When the image renders, you will see a weird colored array and a new layer in your layers dialog. Just delete that new layer and you'll see the result of the watercolor filter.
Step 6. Now go to Colors>Curves and use the "Medium Chrome" settings from the other foil tutorial I posted recently and slightly adjust the curves like so.
And we have an entirely new look to our foil.
As an alternate you might want to try these curve settings as well.
I hope you have fun foiling around with this!
 Post subject: Re: Better Foil
PostPosted: Fri Jan 06, 2012 12:58 am  (#2)
Reminds me of my Wind Shield reflector (don't have to use it now since it's been so cold; lol). :)
PostPosted: Fri Jan 06, 2012 1:33 am  (#3)
Cool effect!! Thanks for the effort and for posting this.
I've been needing some foil for my new mind control ray blocking hat. :mrgreen:
PostPosted: Fri Jan 06, 2012 3:02 am  (#4)
Reminds me of rescue heat blankets.You know those reflective kind. :)
Pretty far out though.Thanks!
Tux i love the hat! What's the cats name?
PostPosted: Fri Jan 06, 2012 3:05 am  (#5)
That's not me, Rod. It's just a funny picture I found on the net. :lol
But, if I had to guess the cat's name, I'd say "Zorgon". :hehe
PostPosted: Fri Jan 06, 2012 3:11 am  (#6)
The step 5 result looked pretty good.
PostPosted: Fri Jan 06, 2012 11:39 am  (#7)
I've used that effect before to make satin rather than foil. Just apply a blur and then bumpmap it rather than running the GMIC filter.
-Rob A>
PostPosted: Fri Jan 06, 2012 11:54 am  (#8)
The cat looks just like my Bengal.
