It is currently Wed Sep 30, 2026 10:46 am
 Post subject: Manually Lomoizing an Image
PostPosted: Sun Jul 25, 2010 4:01 pm  (#1)
I found this tutorial about how to manually lomoize an image.
http://chetanism.blogspot.com/2009/01/add-colors-to-your-pics.html
Here is the text of the tutorial. I've added some notes of my own to it.
  1. Open your image in GIMP.
  2. Select whole photo using 'Select | All'
  3. Shrink the selection by 75 pixels My note: This depends upon the size of your image.
  4. Feather the selection by 300 pixels (Select | Feather) This too depends upon size
  5. Invert the selection (Select | Invert)
  6. Create a new transparent layer and select it
  7. Take the gradient tool, set shape to 'Radial', and add a white to black gradient from center of photo to the bottom side. You can use other colors in your gradient to get interesting effects, too.
  8. Set the gradient layer mode to overlay. Try other layer modes.
  9. If the border looks too dark, reduce the opacity of the gradient layer or ifs less dark then duplicat the gradient layer (make sure the duplicate layer is also set to overlay mode). I got the following result after duplicating the layer.
This is easy to do and quite fun.
For the gradient I used gold (FFDA800) for the FG color and medium brown (A26E2B) for the BG color and set the layer mode to Dodge.
 Post subject: Re: Manually Lomoizing an Image
PostPosted: Sun Jul 25, 2010 6:11 pm  (#2)
that is very pretty "O".....
PostPosted: Sun Jul 25, 2010 8:12 pm  (#3)
Thank you, Molly. :-D
PostPosted: Sun Jul 25, 2010 8:27 pm  (#4)
makes it look like a dreamy place...but it still makes me thing of spiders lurking inside, just waiting to freak me out.
PostPosted: Mon Jul 26, 2010 11:25 am  (#5)
LOL. Yeah. Outhouses are notorious for flies and spiders. Don't like them either. ~shudder~
PostPosted: Mon Jul 26, 2010 1:18 pm  (#6)
Sorry my wife will still not use it. =(
But it looks real cool! =)
PostPosted: Sun Aug 01, 2010 3:12 am  (#7)
Quite successful photo.nice!
