It is currently Wed Sep 30, 2026 10:46 am
 Post subject: A Quick GMIC trick
PostPosted: Wed Jul 28, 2010 10:34 pm  (#1)
STEP 1
Find a nice photo :!: :D
this is from http://www.flickr.com/photos/zakwitnij/ page link http://www.flickr.com/photos/zakwitnij/271249212/
STEP 2
I like make the subject a bit more impressive, more tall ...here just scale up but only the height will work
STEP 3
then open gmic
look under the preview "output option" and change to "new layer"
now in the GMIC filter list menu search Artistic/bw- pencil
You have a button to maximize the preview when you get something good as
DO NOT CLICK OK...BUT "APPLY"
STEP 4
(Click ok will close GMIC , we want still use it )
Now if you did right (changing the gmic output option to "new layer" the focus of GMIC is still on the original
Now we want add some depth and texture to our work, so chose Artistic/BW-Sketch
Now the filter has many options, and may be very slow also to update the preview
But here we just need to capture the main structure so also a rought sketch as this could work
(NOTE this filter may do much more neat and detailed sketch ... i did quickly because i needed only as effect layer
STEP 5
OK NOW you may close GMIC and change the mode of this layer in multiply
... WE ALMOST GOT IT !
STEP 6
NOW Layer new from visible, increase contrast
THIS IS ALL FOR BW...
BUR if you LIKE YOU ADD THE COLORS BACK:
STEP 7
Move the scaled up original on top of the "new from visible layer", and since a want it moody and dark , here i change layer mode to multiply
(that will also darken ...you may experiment other mode for other effects)
NOTE here i didn't do any post work
But adding layer mask to the layers, you may as example lighten the black textures on the ground in front of the house, just painting the layermask (of the sketch layer with grey or black on part to lighten )
 Post subject: Re: A Quick GMIC trick
PostPosted: Wed Jul 28, 2010 11:10 pm  (#2)
and if you don't like the result, :gaah with GMIC you may always burn everything... :sword
:wh :hexer
:gaah :otb
PostPosted: Wed Jul 28, 2010 11:13 pm  (#3)
Thank you for that. Cool. It's good to get some tips for G'MIC. It can be rather intimidating the first time in it.
Fine deal, you give us tips then burn up the results. Ever hear of recycling? :gaah
PostPosted: Wed Jul 28, 2010 11:29 pm  (#4)
I Almost forgot , because i didn't..
If you look well the color version in several area ,as in the path in front of the house and here and there in the garden and the sky
the dark texture is a bit too black
It is very easy to correct, just add a white layermask to the "sketch" layer
Make the layermask active but look the visible.
with a brush using black at low opacity brush over the part you want lighten ...and you may see the result in real time
I may add this tomorrow..now is too late
PostPosted: Thu Jul 29, 2010 11:29 pm  (#5)
That image looks real cool PhotoComix! =P
Here is one i did in G'MIC of some Egyptian pyramids.
PostPosted: Thu Jul 29, 2010 11:54 pm  (#6)
something is happening there...Red flames on the Pyramids
PostPosted: Fri Jul 30, 2010 8:59 pm  (#7)
looks very alien! maybe it's really another dimension coming through!
PostPosted: Mon Aug 02, 2010 4:28 am  (#8)
Well i figured if PC can light a couple fires I could at the very least throw around a few lightning bolts! .. heheh
I almost did add a couple of planets in the night sky, but didnt want to make it too busy. (which it already is) =P
Wilbur popping out of a dimensional window in one of the pyramids would have been cool though!
PostPosted: Mon Aug 02, 2010 9:43 am  (#9)
Your pyramid image is cool, Rod. The lightning connections give me an eerie feeling like the pyramids are communicating. The pyramids always give me a feeling of awe anyway.
PostPosted: Sat Aug 07, 2010 2:30 pm  (#10)
This ... is ... AWESOME :D Seriously, I thought G'MIC was nice, but I never combined different options together like this.
P.S.: If you get the color back in by moving the original layer on top and changing the layer mode to multiplication, you can Blur it by around 20 (for rather big images) and play around with the opacity of the Sketch-layer to make it look even more like a painted picture.
