It is currently Thu Nov 26, 2026 3:29 am
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3  Next
 Post subject: Legos.
PostPosted: Sat Mar 10, 2012 8:05 pm  (#1)
Usually use wacky techniques to create the lego cutout patterns, but, I rediscovered G'MIC's Old School 8-bit preset and it did a good job at it which got me back to thinking legos again. :)
File comment: Turning a photo into a Lego mosaic with the GIMP
Lego.mosaic.with.the.GIMP.pdf [1.56 MiB]
Downloaded 2151 times
 Post subject: Re: Legos.
PostPosted: Sat Mar 10, 2012 9:12 pm  (#2)
I see that Patrick no longer has the original Lego tutorial up on his webpage. Fortunately, there is a cached version on archive.org for those interested in following the original old school method.
PostPosted: Sun Mar 11, 2012 1:00 am  (#3)
Saulgoode,
Thank You for the link :)
Lyle ,great idea :)
PostPosted: Sun Mar 11, 2012 1:26 am  (#4)
Glad I got the patterns before the site got down then Saul. Wonder why the tut's no longer being hosted then? :)
PostPosted: Sun Mar 11, 2012 2:46 am  (#5)
Very cool.
Here is some software that you can use to build images of 3D Lego items. :)
http://ldd.lego.com/download/
PostPosted: Sun Mar 11, 2012 3:02 am  (#6)
Lot's of cool software out there to build these Rod. Have to understand that I'm lazy and prefer to just convert pictures to legos, but you are very limited doing this I know. :)
PostPosted: Sun Jan 11, 2015 12:27 am  (#7)
I went ahead and created a image of the tutorial in case it ever vanishes.
Lego stud pats (5) attached in zip file. :)
lego-studs_RD.zip [9.64 KiB]
Downloaded 550 times
PostPosted: Sun Jan 11, 2015 12:33 am  (#8)
That's the tut alright (and where I also got the dimples as I recall); you now need to get rid of the seam ends of the stud since that's what the program now does. :)
PostPosted: Sun Jan 11, 2015 12:38 am  (#9)
Cool pattern, thanks Rod. :bigthup
PostPosted: Sun Jan 11, 2015 1:03 am  (#10)
Thanks Rod. downloaded and will check out another time
PostPosted: Sun Jan 11, 2015 1:14 am  (#11)
Very cool.
That Lego Digital Designer is awesome.
The lego images you guys made look really nice. :bigthup
PostPosted: Mon Jan 12, 2015 10:46 am  (#12)
Very cool.
I like how you can turn the table to see it 3D. :)
Still trying to figure out how to flip and rotate the lego pieces though.
PostPosted: Mon Jan 12, 2015 10:54 am  (#13)
Very cool.
Yeah that is pretty cool. I didn't create this tank image. I downloaded a Lego Digital Designer LXF Model File (.lxf) and opened it in LDD.
I got the LXF file from here at this Share your LEGO site... http://mocpages.com/
BTW... Made this recently in Gimp.
PostPosted: Sun Feb 01, 2015 5:28 pm  (#14)
SWEEET!
PostPosted: Mon Feb 02, 2015 10:01 am  (#15)
Hmmm, maybe i will try these out in the new Trace Pixels filter in Inkscape -0.91. Turn them to color vector , enlarge them, and create a PHF? Or do you have a larger image of them?
PostPosted: Mon Feb 02, 2015 8:50 pm  (#16)
Sorry Rod, but that's the largest image I have. I made them for a friend and he needed that size.
PostPosted: Mon Feb 02, 2015 10:52 pm  (#17)
Sorry Rod; though pixel trace did a lot better job then the old potrace method (won't even bother sharing that result), it's still a no-go. lol
PostPosted: Tue Jun 09, 2015 7:15 am  (#18)
:paint
PostPosted: Tue Jun 09, 2015 7:43 am  (#19)
love it
PostPosted: Sun Aug 02, 2015 8:25 am  (#20)
:paint
