Learning to make an image of a gear in Gimp
File_New Image
Image Settings: 512x512 pixels
Advanced Options_Fill With:Transparency
Layer Is Named "Background" Automatically
Change Foreground Color to 004660
Toolbox_Bucket Fill Tool: Click background layer
New Layer_Layer Fill Type:Transparency; Name Layer "Gear"
Paintbrush: Circle(19)
Scale Paintbrush: 10
Foreground Color: 808080
Place Cursor At The Center Of The Image: 256x256
Left Click Once
New Brush
Settings:
Shape: Square
Radius: 12
Spikes: 20
Hardness: 1.00
Aspect ratio: 15
Angle: 0
Spacing: 20
Place Cursor At The Center Of Image: 256x256
Left Click Once
Ellipse Select Tool
Left Click And Hold; Press Shift/Control
Drag Size: 80x80
Release Left Click
Press Delete Key On Keyboard
Select Gear Layer In Layer Window
Right Click Gear Layer
Left Click Alpha To Selection
Filters_Light And Shadows_Drop Shadow
Settings:
Offset X: 4
Offset Y: 4
Blur radius: 0
Color: Black
Opacity: 100
Allow resizing checked
Click Ok
Right Click Drop Shadow Layer In Layer Window
Left Click Merge Down
Settings:
Offset X: -2
Offset Y: -2
Blur radius: 0
Color: White
Opacity: 100
Click Ok
Select_None (Or Shift/Control/A)
File_Save
Name: Gear 04_26_2012.xcf
Select where you what the file to be saved
Click Save
File_Save As
Name: Gear 04_26_2012.jpg
Click Save
New window opens_Click export
New window opens_Click save
File_Save As
Name: Gear 04_26_2012.gbr
Click Save
The End
