It is currently Mon Nov 30, 2026 9:43 am
 Post subject: PhotoMaster's Puzzle Tutorial
PostPosted: Thu Aug 26, 2010 6:44 pm  (#1)
This is what the final image looks like.
Note: This is my preferred image. When I did the tutorial, the image came out slightly different.
01) Load image of choice.
02) Layer > Transparency > Add Alpha Channel
03) Name layer "Puzzle"
04) Layer > New Layer > OK
05) Rename "New Layer" as "Bump"
06) Fill new with white
07) Filters > Render > Pattern > Jigsaw (The values shown are suggestions only. Adjust how you like it.)
Horizontal Tiles = 7
Vertical Tiles = 7
Bevel Width = 5
Highlight = 0.5
Style = Square
08) Turn off visibility of "Bump" layer by clicking eye on the layer toolbar.
09) Select "Puzzle" layer in Layer toolbar
10) Filters > Map > Bumpmap (The values shown are suggestions only. Adjust how you like it.)
Bump Map = Bump Layer
Map Type = Sperical
Compensate for darkening = On
Azimuth = 135
Elevation = 15
Depth = 5
All other values = 0
11) Layer > New Layer > OK
12) Rename "New Layer" as "Back"
13) Fill "Back" layer with background color of choice.
14) Layer > Stack > Layer to Bottom
15) Turn off visibility of "Puzzle" layer by clicking eye on the layer toolbar.
16) Turn on visibility of "Bump" layer by clicking eye on the layer toolbar.
17) Select "Bump" layer in layer toolbar
18) Using magic wand tool to select pieces to remove.
19) Turn off visibility of "Bump" layer by clicking eye on the layer toolbar.
20) Using rectangle slection tool and holding shift, Select all common separators.
This
Becomes This!
21) Select "Puzzle" layer
22) Edit > Cut
23) Edit > Paste
Click on new layer button to make pasted selection it's own layer.
24) Name new layer as "Pieces".
I recommend turning the visibility on and off for Puzzle and Pieces layers so you see what you have.
25) Image > Canvas Size > % > 140% (The values shown are suggestions only. Adjust how you like it.)
26) Select "Back" layer.
27) Layers > Layer to Image Size
28) Re-fill "Back" layer with selected color
29) View > Zoom > Fit Image in Window
30) Select "Puzzle" layer
31) Using Move tool drag "Puzzle" layer to middle of screen.
32) Using Rotate tool, rotate "Puzzle" layer to desired angle.
33) Using Move tool, move "Puzzle" layer to desired position.
34) Repeat steps 30 to 33 for "Pieces" Layer
35) Layer > New Layer > OK
36) Rename "New Layer" as "Shadow"
37) Select "Puzzle" layer
38) Select > Alpha to Selection.
39) Select "Shadow" Layer.
40) Fill selection on "Shadow" layer with black
41) Select "Pieces" layer
42) Select > Alpha to Selection.
43) Select "Shadow" Layer.
44) Fill selection on "Shadow" layer with black
45) Select > None
46) Filters > Blur > Gaussian Blur > (The values shown are suggestions only. Adjust how you like it.)
X = 15
Y = 15
47) Set opacity of "Shadow" layer to 30%. (The values shown are suggestions only. Adjust how you like it.)
48) Move shadow layer down below "Pieces" and "Puzzle" Layer.
49) Using move tool, Move "Shadow" layer about 15 pixels right and 15 Pixels down (Approx - The values shown are suggestions only. Adjust how you like it.).
50) Select "Back" layer.
51) Filters > Artistic > Apply Canvas
Top Left
4
When posting on-line, I suggest rescaling image smaller, keeping your full sized image intact.
Have fun!
My Sigs = My Photos
 Post subject: Re: PhotoMaster's Puzzle Tutorial
PostPosted: Fri Aug 27, 2010 2:12 pm  (#2)
I love this tutorial. :jumpclap
PostPosted: Fri Aug 27, 2010 7:17 pm  (#3)
Awesome puzzle! Great cat image and excellent execution!
My Sigs = My Photos
PostPosted: Fri Aug 27, 2010 7:47 pm  (#4)
Very nice, would you mind if i used this tutorial in our first Gimp Magazine?
PostPosted: Fri Aug 27, 2010 10:02 pm  (#5)
I hope I have time to do this tut soon, the first time I tried it, I was following it blindly. Now I think I will actually understand what I am doing!
PostPosted: Fri Aug 27, 2010 10:17 pm  (#6)
I love the great results everyone is coming up with!
My Sigs = My Photos
PostPosted: Mon Aug 30, 2010 5:44 am  (#7)
I tried too but I didn't had the result I wanted too.maybe if I find more time I'll made it.
Very good tutorial.
PostPosted: Sat Dec 29, 2012 3:55 am  (#8)
Here's one using my favourite boys!
PostPosted: Sat Dec 29, 2012 4:29 am  (#9)
That is very nice Silvertayl, long time no see.
PostPosted: Sat Dec 29, 2012 3:24 pm  (#10)
I keep meaning to use this tutorial again, but never seem to find the time!
PostPosted: Sat Dec 29, 2012 7:21 pm  (#11)
I had a go....
Gareth Kitchener
Bedfordshire, England
PostPosted: Sat Dec 29, 2012 7:23 pm  (#12)
Hi Molly. :)
Yes it's been awhile.
I did some others when I was following this tut on Gimp Talk. I'll post them soon.
PostPosted: Sat Dec 29, 2012 7:34 pm  (#13)
That's really good Hatter. :cute I particularly like the curvy puzzle pieces and that's a great photo. :clap
PostPosted: Sun Dec 30, 2012 7:22 am  (#14)
Thanks, Silvertayl.
Gareth Kitchener
PostPosted: Sun Dec 30, 2012 7:32 am  (#15)
Very nice Hatter!
PostPosted: Sun Dec 30, 2012 8:47 am  (#16)
Thanks, Molly.
Gareth Kitchener
PostPosted: Sun Dec 30, 2012 11:35 pm  (#17)
Here's some I prepared earlier. :lol
PostPosted: Mon Dec 31, 2012 12:26 am  (#18)
Love this tut. Worked really well on one of my previous manips. I'm pleased with the results. (And I just 'puzzled' out how to do thumbnails on here. Go me.)
PostPosted: Mon Dec 31, 2012 2:34 pm  (#19)
What fun to go back and redo some old tutorials, now that I am more familiar with Gimp, it does go faster and easier...however, I'm not sure how to have the black lines between the puzzle pieces a bit less sharp. It makes the pieces look too "outlined", especially where the pieces are removed.
PostPosted: Mon Dec 31, 2012 8:01 pm  (#20)
And some more. :)
