It is currently Fri Oct 09, 2026 4:19 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3  Next
 Post subject: Easy Lightning Tutorial
PostPosted: Tue May 22, 2012 11:46 am  (#1)
Create a new document - mine is 600x800 - select a large hard round brush and colour one half of the page black so that the division is the shape of your lightning bolt.
Run filters/blur/gaussian blur choosing 100px for both x and y.
Open filters/render/clouds/difference clouds, choose the following values then click OK.
Select colours/invert colours
Select colours/levels and push the left hand input slider to the right until you are happy with the lightning.
Colour/colourize - I chose these values
Good for electrical sparks too! (Maybe your control panel is short-circuiting Drac.)
 Post subject: Re: Easy Lightning Tutorial
PostPosted: Tue May 22, 2012 12:02 pm  (#2)
I had a script for this but 2.8 broke it somehow. It doesn't run and locks up scriptfu.exe and such. This will work great until I get it fixed, so thanks :teeth
PostPosted: Tue May 22, 2012 12:12 pm  (#3)
No problem - have fun!
PostPosted: Tue May 22, 2012 12:49 pm  (#4)
You're right, that was pretty easy. Thanks for the idea. There may be a couple of loose wires on my control panel but they're mostly just in my head.
PostPosted: Tue May 22, 2012 12:51 pm  (#5)
In fact I think this is the same technique he uses in his script :D
PostPosted: Tue May 22, 2012 1:21 pm  (#6)
Easy/breezy tut with pretty good results. Thanks for sharing it Erisian. :)
PostPosted: Tue May 22, 2012 1:28 pm  (#7)
Glad you like it Lyle. :)
PostPosted: Tue May 22, 2012 1:52 pm  (#8)
PostPosted: Tue May 22, 2012 1:54 pm  (#9)
Thanks Erisian,
nice and easy, I resized it so wouldn't take as much room.
PostPosted: Tue May 22, 2012 1:55 pm  (#10)
Beautiful Molly. I might try an animated version.
PostPosted: Tue May 22, 2012 2:10 pm  (#11)
Looks like erisian has become the lightning god here! A resurrection of Thor himself :teeth
PostPosted: Tue May 22, 2012 2:13 pm  (#12)
Hey Drac and ZWard, where are yours?
PostPosted: Tue May 22, 2012 2:15 pm  (#13)
Yeah, let's see what yer made of!
PostPosted: Tue May 22, 2012 2:38 pm  (#14)
Don't get your drawers in a knot, I was just finishing up. I played with it a bit duplicating the layer and blurring it 100% to make a glow and cleaning up the rough places wiht a fuzzy brush. Threw this together really fast so no pickin' allowed.
Edit: Oops. Guess it helps to attach the pic.
PostPosted: Tue May 22, 2012 2:42 pm  (#15)
Wow! Nice work. :clap :hi5
PostPosted: Tue May 22, 2012 2:50 pm  (#16)
Heck the lightning was the easiest part! Wait......hold on a sec.........I'm beginning to see something...yes it's getting cearer now....lots and lots of lightning brush posts in your future.
PostPosted: Tue May 22, 2012 3:02 pm  (#17)
Added a few passes of AAA Good Vibrations (50 and 25 periods) then after the cloud step, added some low amplitude sparkle to the result. :)
PostPosted: Tue May 22, 2012 3:05 pm  (#18)
That's really cool Lyle. I can almost imagine an abandoned keep on top of a mountain.
PostPosted: Tue May 22, 2012 3:06 pm  (#19)
Ahem! :hoh
PostPosted: Tue May 22, 2012 3:06 pm  (#20)
Like this way much better; Easier to adjust to user preference :D
Just a simple throw together, so much fun though :teeth
QUIT THE NINJAS! 5 times!!!!
