It is currently Sun Oct 04, 2026 8:03 pm
 Post subject: Circle of Ring Tutorial
PostPosted: Fri May 25, 2012 5:07 pm  (#1)
Making a Circle Ring
This is a tutorial where someone requested how to make a circle of ring. There are many ways to do this and this is one of them.
First of all, open a new image. File > New > width 800 pixels, Height 600 pixels, OK This will be called your background layer.
Add new transparent layer, Ok
On this transparent layer, make a circle using your Ellipse Select Tool :elipse In the toolbox image it shows you to click expand from center and fixed (Aspect ratio) click size and make it 500x500.
Click your layer and then click your alignment tool :alntool Then click the top center :alntop and the :alnmid
This will center your elipse.
Select > To Path > Select > None
Go to your paint brush tool :brush go to your brush folder and select a brush you want to use for your circle. In my case I chose the silver bearing brush set at 75.3 spacing and scale 0.40. paint your brush on your empty white layer and adjust the spacing until you are satisfied with the distance between the beads. After you decide what spacing and size brush you want, erase every thing you have on the sphere layer. Leave the sphere layer selected.
Go to your paths dialog :pathtab Click on your selection and go to botton of your path dialog and click the :pap (Paint along Path) click beside Stroke with paint tool. Make sure that beside paint tool paintbrush is selected. then click stroke.
Now your beads should show up.
Go back to your Layer dialog :layertab and you will see your bead layer on top and your plain white background below. If you want to change the color of your background, double click your foreground color tool which the default is black and change to the color of your choosing for your background. I will choose black, Select the background to make it active and drag your color over to your main window with the beads. I now have a circle of beads on a black blackground.
If you don't want a background, turn off the background layer by clicking the eye. Once you have your ellipse saved in your paths dialog, you can use that again to make another circle with a different brush or colors.
If you have any questions, please post back in this Tutorial.
 Post subject: Re: Circle of Ring Tutorial
PostPosted: Sat May 26, 2012 10:48 am  (#2)
Nice tute. Not easy getting the spacing right though.
PostPosted: Sat May 26, 2012 11:09 am  (#3)
Very pretty erisian. Did you leave the ring there on purpose.
PostPosted: Sat May 26, 2012 11:11 am  (#4)
Yes Molly. I re-stroked it to about 4 pixels on a different layer before merging down and bevelling.
PostPosted: Sat May 26, 2012 11:13 am  (#5)
I see, just wondered... looks good
PostPosted: Sat May 26, 2012 11:14 am  (#6)
Thank you. :)
PostPosted: Sat May 26, 2012 1:29 pm  (#7)
Here is another option you can use this for. I used a little pearl I made into a paint brush.
PostPosted: Sat May 26, 2012 1:31 pm  (#8)
That's gorgeous Molly. I like the sparkle.
PostPosted: Sat May 26, 2012 1:38 pm  (#9)
Thanks, That is from that real diamond in the clasp :teeth
PostPosted: Sat May 26, 2012 1:43 pm  (#10)
I'll take you word for it. :hoh
PostPosted: Sat May 26, 2012 2:59 pm  (#11)
You inspired me Mo. :)
PostPosted: Sat May 26, 2012 3:37 pm  (#12)
Now isn't that a sexy bracelet. woo hoo :gimp :coolthup
PostPosted: Sat May 26, 2012 4:17 pm  (#13)
Thanks Mo. :) :) :)
PostPosted: Sat May 26, 2012 9:55 pm  (#14)
how do I keep the top bead from overlapping? Also, is there an easy way to make a second layer match the first one or is it trial by error...mostly error, lol. I made a sparkle layer over the mardi gras bead layer but couldn't get them lined up perfectly after a bunch of tries, so I just left it random.
PostPosted: Sun May 27, 2012 5:21 am  (#15)
You just have to keep experimenting with your brush spacing. I found it really difficult to get right so I just cut the beads and put a gold link there instead. I don't know how you would line up your sparkles. You've done a beautiful job there 2-ton, that's a lovely blue.
PostPosted: Sun May 27, 2012 5:32 am  (#16)
very pretty 2-ton.
I just use a sparkle brush and put a few random ones here and there.
PostPosted: Sun May 27, 2012 5:47 am  (#17)
very pretty 2-ton.
Technically the sparkles should all be at the same place on all beads.
PostPosted: Sun May 27, 2012 6:22 am  (#18)
I agree, where the light hits, they should be all the same, but if the beads are not all perfectly round I think some of the edges can catch sparkles in different places.
Anyway, 2-ton you could paint one of your beads on a layer, then put a sparkle on it and save it as a brush. If you do that, then you will have the sparkles all in the same place on each bead when you do your stroke.
I also see the problem with the beads over lapping at the join. I don't know if there is a fix in this method or not.
PostPosted: Tue May 29, 2012 7:18 am  (#19)
Erisian, Michelle Obama is wearing your blue bead necklace on Good Morning America this mornng!
PostPosted: Tue May 29, 2012 7:26 am  (#20)
Thanks for telling me - I'll get the Feds in. :mrgreen:
