It is currently Mon Oct 05, 2026 7:25 am
 Post subject: Uber easy sketch effect.
PostPosted: Sat Jun 30, 2012 8:06 pm  (#1)
Requirements: Wavelet Denoise plugin: http://registry.gimp.org/node/4235
ref: http://www.sxc.hu/photo/941938
Shared earlier a sketch that I did on another forum and thought, well, I should share more of my secrets with you all. I actually concocted this effect a few months back and have used for various sketches since then (again other forums I frequent). I usually add other filters to the mix such as Impressionist plugin and such, for enhanced sketch like result, but for now, this result only uses the plugin so you can see the full effect of this technique.
1) Open target and then duplicate layer.
2) On top layer run the filter with the following settings:
3) On the base layer run the filter with the following settings (alternative method is to just open the image run the filter with the above settings dup and do so again with the new layer, but that's the lazy man's approximation):
4) Set Top layer to Grain Extract then flatten.
5) Autolevel then desaturate. Simple as that. :)
 Post subject: Re: Uber easy sketch effect.
PostPosted: Sun Jul 01, 2012 3:04 am  (#2)
Excellent Idea Lyle, definite food for thought there
PostPosted: Sun Jul 01, 2012 11:24 am  (#3)
Interesting effect. I would have posted my results but it made me look old. I'll try again on a different image. Thanks Lyle.
PostPosted: Sun Jul 01, 2012 1:27 pm  (#4)
Cool !
PostPosted: Sun Jul 01, 2012 3:00 pm  (#5)
Thanks for all the comments. As for you Erisian, guess what? You are old. lolololol
Again, this is just the first pass of what will be other blends to make it more pencil like. It's close but no cigar for a sketch effect on it's own, but some may like the effect since if comes close to a pencil rub like result. :)
PostPosted: Sun Jul 01, 2012 3:05 pm  (#6)
Approaching 97 but I use Camay.
PostPosted: Sun Jul 01, 2012 8:43 pm  (#7)
That's one of the nice things about this forum, there are a lot of old guys in it.
PostPosted: Mon Jul 02, 2012 1:39 am  (#8)
That's neat, thanks oh and btw old gals too...well not as old as you guys :p
