It is currently Tue Oct 06, 2026 6:41 pm
 Post subject: Light and Waves Part 1: Basic Beams
PostPosted: Tue Jul 24, 2012 11:47 am  (#1)
Time for the first TUT! Finally finished this at 11 PM my time. Justpast.it was being an arse so I chose to just publish it as a pdf myself.
Here it is:
Part 1 (1).pdf [684.47 KiB]
Downloaded 772 times
PS: I may end up doing a speed version on youtube or a full version if wanted. If asked for expect it in about 20 years :D
EDIT: New pdf version with better quality pictures
 Post subject: Re: Light and Waves Part 1: Basic Beams
PostPosted: Tue Jul 24, 2012 12:38 pm  (#2)
Looking good.
Thanks ZWard! :)
PostPosted: Tue Jul 24, 2012 12:39 pm  (#3)
Not a prob. Part two is underway.
PostPosted: Tue Jul 24, 2012 12:57 pm  (#4)
One problem though is most of the PDF images are very blurry and hard to read or see the values you use.
PostPosted: Tue Jul 24, 2012 1:03 pm  (#5)
Really? I'll have to fix that and repost it.
PostPosted: Tue Jul 24, 2012 1:07 pm  (#6)
What program are you using to create the PDF's? If it's PDF Creator and not Adobe, Rod is right on. You have to really pay attention to the settings or the resolution sucks bigtime.
PostPosted: Tue Jul 24, 2012 1:14 pm  (#7)
I fixed it, I accidentally used web size instead of print or publication quality.
PostPosted: Tue Jul 24, 2012 5:15 pm  (#8)
Much better! :)
PostPosted: Wed Jul 25, 2012 11:07 am  (#9)
Sorry about that, it was getting late and my head was getting fuzzy ;P
PostPosted: Wed Jul 25, 2012 3:39 pm  (#10)
I know the feeling! :)
PostPosted: Wed Jul 25, 2012 9:58 pm  (#11)
ZWard117 a Great tutorial (well explained with clear directions ), ready for part 2 now.
I'm looking forward to it,as it's still wet and cold outside (I've lots to do there when it clears)
I added the sparks brush for effect
PostPosted: Thu Jul 26, 2012 12:40 pm  (#12)
Looks nice, haven't used that gradient before but man does it look good with that set of blur
PostPosted: Sun Aug 19, 2012 2:52 pm  (#13)
this looks fun, i'm having restricted internet access right now but i'll definitely try this once i've been able to download the pdf. your light beam image looks amazing, zward!
PostPosted: Mon Aug 20, 2012 8:31 am  (#14)
a very good tutorial, zward117, so easy to follow. i had great fun playing with light beams - as the attachment hopefully shows :).
File comment: light beams with text, small version
PostPosted: Mon Aug 20, 2012 8:36 am  (#15)
Very nice job AnMal
PostPosted: Mon Aug 20, 2012 8:41 am  (#16)
wow, AnMal, those really put your eyes out!!!!
PostPosted: Mon Aug 20, 2012 10:00 am  (#17)
Nice work AnMal.
Hey Z - When's Part II gonna be posted?
PostPosted: Mon Aug 20, 2012 10:07 am  (#18)
DISCO ! :rockon
how did you create the wavy beam ?
PostPosted: Mon Aug 20, 2012 1:06 pm  (#19)
Sorry guys, still righting everything up. I have a job now that takes me away from my computer all day long, and when I'm not working I'm sleeping alot because its 12 hours of customers. I am still working it out, hopefully not to much longer :|
PostPosted: Mon Aug 20, 2012 1:38 pm  (#20)
Cool beans! I guess we'll just chill 'til you git 'er done.
