It is currently Sun Oct 04, 2026 8:02 pm
 Post subject: Photo Text
PostPosted: Sun Aug 05, 2012 4:12 pm  (#1)
I was reading a Photoshop tutorial about using a "clipping mask" for text and I wondered if something similar could be done in Gimp. This is what I came up with.
Type some text in a mid grey using a bold font.
Open a photo on top as a new layer and put the layer into overlay mode.
Now you can move the photo around as you wish and still edit the text.
 Post subject: Re: Photo Text
PostPosted: Sun Aug 05, 2012 4:25 pm  (#2)
you can do that with a layermask as well
PostPosted: Sun Aug 05, 2012 4:28 pm  (#3)
But do you have the flexibility of adjusting the photo and editing the text with a layer mask? I'll have to look into that.
PostPosted: Sun Aug 05, 2012 4:29 pm  (#4)
i think so
you can manipulate each layer on its own
PostPosted: Sun Aug 05, 2012 5:33 pm  (#5)
Cool Erisian.
PostPosted: Sun Aug 05, 2012 6:02 pm  (#6)
Thanks Mo.
PostPosted: Sun Aug 05, 2012 7:27 pm  (#7)
Very cool, and while I like layer masks, this is a great alternative.
PostPosted: Mon Aug 06, 2012 2:58 pm  (#8)
Thank you 2-ton.
