It is currently Wed Nov 25, 2026 3:15 am
 Post subject: Satin Tutorial
PostPosted: Sun Aug 12, 2012 10:40 am  (#1)
I can't remember where I found this one originally but I've added a Draconian twist to make the satin really shine.
1. Create a new 600x600 document, select the gradient fill tool and in tool options change the mode to difference. Make sure fg to bg RGB is selected. Create a new white layer, name it "Material" and repeatedly run your gradient fill over it at different angles until you achieve something like the image below.
2. Open Filters>Blur>Gaussian Blur and set it to 30 pixels x and y and click OK. Open Filters>Edge Detect>Edge and click OK. You will have an almost totally black image. Select Colours>invert then colurs>levels and push the left input (top) slider towards the right until you have a good contrast. Open Filters>Blur>Gaussian Blur and set the x and y values to 8 and click on OK.
3. Here's the Draconian bit. Duplicate the layer then open Colours>Curves and copy this curve.
4. Reduce the opacity a little until you have a nice soft satin look then merge the layer down.
5. Use Colours>colourize to colour your satin.
6. You might want to add some text or a design. Type some text in a bold font and a colour of your choice and size and position it. Right click the layer and choose Layer to image size.
7. Open Filters>Map>Displace and make sure both maps are set to the material layer. If the text looks too broken up, try reducing both values to about 10. Put your layer into Grain Merge mode and make any final adjustments you need to make.
I hope this is useful to you.
 Post subject: Re: Satin Tutorial
PostPosted: Sun Aug 12, 2012 10:52 am  (#2)
Maybe here http://fence-post.deviantart.com/art/Sa ... P-46937633 or on GT
there is also a script http://fence-post.deviantart.com/art/GI ... t-77556760
BTW nice tut
PostPosted: Sun Aug 12, 2012 10:58 am  (#3)
Thanks PC. I rarely look at DA and I'm sure it was a video tutorial I saw so it was probably on Youtube somewhere. In case you see this Fence-post, thank you for the script.
PostPosted: Sun Aug 12, 2012 11:31 am  (#4)
GimpTricks did a satin tutorial
http://www.youtube.com/watch?v=IFZ8cQ2r2Dg
http://www.youtube.com/watch?v=PNIzvdwTCcE
PostPosted: Sun Aug 12, 2012 11:43 am  (#5)
Might well have been the one. I've watched all of hers as I became addicted to her Dutch accent and she was a good teacher.
PostPosted: Sun Aug 12, 2012 12:00 pm  (#6)
same here, hope she will get better :(
PostPosted: Sun Aug 12, 2012 12:03 pm  (#7)
Likewise. :)
PostPosted: Sun Aug 12, 2012 12:11 pm  (#8)
I don't usually download from YouTube, but here's a trick you may not know.
At YouTube when you open your video add, pwn to the URL like so,
pwnyoutube
Hit enter for additional download options.
PostPosted: Sun Aug 12, 2012 12:55 pm  (#9)
lol, there are tons of choices and some look pretty interesting...not sure I would use any of them except the usa proxy thingy...but it looks a bit difficult.
PostPosted: Tue Nov 28, 2017 4:00 am  (#10)
Just for info, I've added a Satin filter into G'MIC yesterday, following the tutorial from fence-post.
Enjoy! :bigthup
PostPosted: Tue Nov 28, 2017 11:51 am  (#11)
Very well written!
My Sigs = My Photos
PostPosted: Tue Nov 28, 2017 12:38 pm  (#12)
The G'Mic Satin Filter works pretty sweety!
My Sigs = My Photos
PostPosted: Tue Nov 28, 2017 8:29 pm  (#13)
This works great on flags too...
PostPosted: Tue Nov 28, 2017 8:48 pm  (#14)
Sweet flag!
My Sigs = My Photos
