It is currently Mon Oct 05, 2026 9:02 pm
 Post subject: Revised Metallic Gradients
PostPosted: Mon Aug 20, 2012 10:32 am  (#1)
Sorry for the inconvenience, but it appears that due to a typo when creating and labeling my gradients, they appear in the Blend tool dialog as "Mellalic" rather than "Metallic". The files are named correctly in the gradient folder but only the lable is still incorrect.
Evidently after I named and saved the first gradient, I perpetrated the error on all of them because I only changed the number on subsequent saves. I have since revised the lables on all of them and I have already updated the zip file attached to my original tutorial post here:
viewtopic.php?f=23&t=4097&p=50500#p50500
This has gone unnoticed for a while now but just wanted to get it corrected. If you have these gradients, please download the revised zip and replace the original Metallic gradient files. :oops:
 Post subject: Re: Revised Metallic Gradients
PostPosted: Mon Aug 20, 2012 11:02 am  (#2)
Drac, are the files still the same, but just the spelling is incorrect? If so, I will leave them as they are. I can live with one "L" instead of two.
PostPosted: Mon Aug 20, 2012 1:42 pm  (#3)
Yeah the files are still named the same in the folder and it's actually too many "Ls" and a missing "T". :)
but it's when you open the Blend tool dialog and go to select a gradient from the list that it says "Mellalic" if you have the old files installed.
The revised sip has them labled correctly to show up right in the list as shown above. I just wanted it to be correct.
I made sure I typed this real slow cuz I know you don't read too fast. :rofl
PostPosted: Mon Aug 20, 2012 1:57 pm  (#4)
:hoh :geek: grrrr. I didn't even notice the typo's,
PostPosted: Mon Aug 20, 2012 3:10 pm  (#5)
Seems it's what I do best lately. :hehe :hugme
PostPosted: Mon Aug 20, 2012 3:22 pm  (#6)
:oops: :oops:
PostPosted: Mon Aug 20, 2012 3:57 pm  (#7)
I'm keeping the old ones to remember you by Drac. :hehe
PostPosted: Tue Aug 21, 2012 6:55 am  (#8)
Fantastic! Stupidity in perpetuity. :rofl
