It is currently Thu Oct 08, 2026 3:50 am
 Post subject: Make a Rainbow
PostPosted: Wed Jun 10, 2009 12:04 pm  (#1)
This tutorial is fast and easy to do.
Make a large canvas. Your rainbow will end up about 56% of the width. I started with a canvas of 750 x 750px. The resulting rainbow circle was 414px x 414px.
Fill the background layer with white. The background layer can be deleted later but it helps you to see the colors.
Make a new transparent layer.
Using the Rectangle Select Tool, make a rectangle about halfway down on the canvas that fills the width of the canvas and as high as you want your rainbow thick. For this rainbow I made the height of the selection 75px.
Fill the selection with the rainbow gradient by holding down the Ctrl key and dragging from top to bottom of the selection.
Unselect.
Filters > Distorts > Polar Coordinates.
Settings:
Circle depth in percent: 100
Offset angle: 180
Preview and To Polar = checked.
Map backwards and Map from top = unchecked.
You will see a circle in the preview window.
Click OK.
You will have a rainbow circle on your canvas.
Use the Rectangle Select Tool and select the bottom half of the circle. A little more than half looks a little better. Delete. You have a rainbow arc.
Using the Crop Tool, roughly crop around your rainbow, leave some canvas around it so you have room to work around your rainbow. After you have selected the area around the rainbow, click in the center of the selection. You may have click twice. It will crop to the size of your selection.
Ctrl + E will remove excess canvas around your image.
Filters > Blur > Gaussian Blur. Blur your rainbow just a little - a setting of 1 or 2. I used 2 on this rainbow.
Decorate your rainbow with what you want.
Download the pdf file of this tutorial (MakeARainbow.pdf).
Download my rainbow gradient (Rainbow.ggr).
MakeARainbow.pdf [123.72 KiB]
Downloaded 656 times
Rainbow.ggr [674 Bytes]
Downloaded 738 times
 Post subject: Re: Make a Rainbow
PostPosted: Thu Sep 09, 2010 8:43 pm  (#2)
Nice simple tutorial! I love that you included the gradient and a PDF file!
My Sigs = My Photos
PostPosted: Thu Sep 09, 2010 8:47 pm  (#3)
I had forgotten all about this tut. Made it over a year ago before Gimp Chat got updated to its present state.
PostPosted: Thu Sep 09, 2010 8:56 pm  (#4)
I love going back and re-discovering posts.
My Sigs = My Photos
PostPosted: Thu Sep 09, 2010 9:28 pm  (#5)
I also love quick and easy!
PostPosted: Thu Sep 09, 2010 9:38 pm  (#6)
Simple is where its at ;)
Nice tutorial O!
Oh and thanks for the nice gradient.
PostPosted: Mon Aug 25, 2014 9:25 am  (#7)
oregonian,
thanks for sharing the Rainbow
I have the rainbow made in gimp then used in another forum and Also in gimpchat
gimper66
PostPosted: Mon Aug 25, 2014 12:54 pm  (#8)
Very, very nice gimper66. Thank you for doing my tutorial and making it a lovely animation. :bigthup
