It is currently Wed Oct 07, 2026 3:31 pm
 Post subject: Fake extrusion - Easy way to get 3D effect (mainly with text)
PostPosted: Mon Sep 24, 2012 11:32 pm  (#1)
Requirements:
*GIMP 2.8
*Optional: Some extra gradients such as in GPS (Gimp Paint Studio) or that can be found in deviantArt.
*Patience with my probably poor English
Well, I start showing the workspace we will use in GIMP:
As first step we open a new image with transparent background and 500px x 500px size. There we put the text to be used as a template. Remember that the size can not exceed the previously mentioned. Use a big font size and bold style, as seen in the picture above.
Now select the tool "Move Tool" and click on the text. With right click "Edit" > "Copy". You now can see in (A) that the first brush is the text copied to the Clipboard. It will stay there unless you copy something new to the clipboard.
Now open a new image with a white background for better visualization, and large size (1000 x 1000 for example). Put a new transparent layer over the white background (Layer > New Layer).
Now let's configure GIMP as shown in the image. We chose two colors on front and back. Select "Paintbrush Tool" and select the text copied to the clipboard as a brush (A). In "Spacing" down to a minimum value as shown in (B). Click on the dynamics button (C), and in the opened window click on the button in down right corner:"Open the dynamics selection dialog". You will see a new tab on the top right of GIMP screen called "Paint Dynamics" and click on the second button down: "Craete a new dynamics". You will see a new tab that is the "Paint Dynamics Editor" and you can rename this new dynamic as you like. There check the color-fade as shown in (D).
Now you choose a large size of the "Paintbrush Tool" in size bar (300 or more, for example). Paint the text stored in the clipboard with a left mouse button single click, as shown in the following image:
Press and keep pressing the Shift key, move a small displacement and then make a single click again. You now can get designs like those shown below:
You can invert the colors, or use "Airbrush Tool" instead of "Paintbrush Tool" as the last text design.
You can also play with the values ​​of "Fade length" (E), or choosing different gradients in (F). You can get designs as shown below:
For the last three designs I've also checked the size-fade box on the "Paint Dynamics Editor". If you check this box, when you paint you must first make a very small displacement with the left mouse button pressed and then release the button. Then hold down the Shift key on the keyboard and do what was said above.
You can use any drawing as a template instead of text. While it not exceed 500px x 500px size. For example below I used the drawing of Wilber:
For the last design I have uncheck the color-fade box and check the size-fade box. Also I made a curved path with "Paths Tool". Then Edit > Stroke Path. Stroke with a paint tool > Airbrush. Check the box "Emulate brush dynamics".
Well, the possibilities are endless. You can use Perspective Tool or also apply filters as Bevel or lighting effects.
Here I used perspective text as stamp template (first image):
Finally mention that if you use a very large brush size you can get imperfections, mainly on the edges, such jagged edges. You can easily correct that applying filters or any method to enhance hot pixels or edges, such as the filter "Enhancement" > "Remove hot pixels" in G'MIC:
I'm sure you can find many new designs :paint
Tags: gimp photoshop 3D text extrusion
 Post subject: Re: Fake extrusion - Easy way to get 3D effect (mainly with text)
PostPosted: Tue Sep 25, 2012 8:30 am  (#2)
Nice tutorial and lots of good examples.
PostPosted: Tue Sep 25, 2012 10:39 am  (#3)
i will have to try this
PostPosted: Tue Sep 25, 2012 10:46 am  (#4)
Awesome, I love this. Must try tonight!!!!
PostPosted: Wed Sep 26, 2012 7:59 am  (#5)
Thank you all. You tell me if something is not clear or not understandable in the tutorial.
Before I had written about the maximum size of the image to copy to clipboard for use as a brush (500px). Does anyone know why this limitation?
PostPosted: Wed Sep 26, 2012 10:18 am  (#6)
I am ever so grateful for the walk through of doing the brush dynamics. I am happy to have had that experience. I played with your tutorial YAFU and had lots of fun. This is just a small part of what I was doing with it. I particularly like using the airbrush. It has an ethereal quality to it.
PostPosted: Wed Sep 26, 2012 1:21 pm  (#7)
Nice!
Yes, brush dynamics are cool!
I think GIMP developers could improve and incorporate some small things to make GIMP a very good tool to easy emulate 3D effects. And it would be great if some of the very good plugins writers here could automate these methods on a single plugin with preview capabilities :)
PostPosted: Wed Sep 26, 2012 9:35 pm  (#8)
I would have never found all the dynamic and how to change them without your tutorial!
PostPosted: Thu Sep 27, 2012 4:25 pm  (#9)
YAFU: thank you for this tutorial - i learned a lot about brush dynamics and enjoyed the text effects i could make.
PostPosted: Thu Sep 27, 2012 10:03 pm  (#10)
@2-ton, AnMal: I'm glad this tutorial has been useful to you to learn about brush dynamics and that you had fun for a while.
PostPosted: Sat Dec 01, 2012 7:28 pm  (#11)
Those images are all great YAFU. You must have had lots of fun doing all of those. I know Gimp is endless in what you can learn and do without going anywhere else.
Thank you for sharing.
PostPosted: Sat Dec 01, 2012 8:02 pm  (#12)
Thank you molly.
Yes, I had fun and it was also useful for learning while I did the tutorial.
PostPosted: Sat Dec 01, 2012 8:31 pm  (#13)
Somehow missed this when it first was shared. Very cool info indeed Yafu and thanks for sharing it. :)
PostPosted: Sat Dec 01, 2012 10:29 pm  (#14)
Thanks lylejk :)
PostPosted: Mon Dec 03, 2012 9:25 am  (#15)
Excellent tutorial.
It is incredible to notice how many combinations the Brush Dynamics offers in yielding amazing results.
Thanks for sharing this technique. :tyspin
PostPosted: Mon Dec 03, 2012 10:18 am  (#16)
Very nice gimp-worms, Gino :)
PostPosted: Sun Aug 04, 2013 2:10 pm  (#17)
I generally use the standard brushes, and I have little familiarity with brushes, almost none.
I will try this tutorial, I think I'll learn a lot!
Thank you YAFU!
PS: Thank you also to AnMal for having indicated this topic. (viewtopic.php?f=8&t=8149#p105467)
bbbbbbbbbbbImage
PostPosted: Sun Aug 04, 2013 2:49 pm  (#18)
Thanks Akros.
Currently there is a bug that can affect this tutorial if you use as brush from clipboard an image that have different colors in top and below:
https://bugzilla.gnome.org/show_bug.cgi?id=703468
No problem for images with one color. In the tutorial this bug should not affect any of the examples because the kind of dynamics used. Except the last of Wilber.
PostPosted: Sun Aug 04, 2013 2:55 pm  (#19)
Thank you YAFU!
This tutorial is worth trying! Definitely.
@ Gino nice result!
