It is currently Tue Nov 24, 2026 1:52 pm
 Post subject: folded and cut papercraft text
PostPosted: Thu Oct 25, 2012 8:52 pm  (#1)
Gimp-Tutorials.net
 Post subject: Re: folded and cut papercraft text
PostPosted: Thu Oct 25, 2012 8:57 pm  (#2)
I like the metal texture one better alc; really does look like cut and bent metal plates. :)
PostPosted: Thu Oct 25, 2012 9:30 pm  (#3)
i've seen that tutorial before, the effect is very nice !
a music producer called Sunchase has a logo thats made in the same way
and while we are talking of papercut, i like this cover by a guy called Xtrah
its a digital origami effect
PostPosted: Thu Oct 25, 2012 9:46 pm  (#4)
Ahhh, digital origami is so amazing. It has to be really hard to get anything that looks realistic!
“For man, as for flower and beast and bird, the supreme triumph is to be most vividly, most perfectly alive.” David Herbert Lawrence
PostPosted: Thu Oct 25, 2012 10:13 pm  (#5)
you could recreate that really easy
just make your shapes with the path tool and stroke it with a gradient
PostPosted: Fri Oct 26, 2012 8:08 am  (#6)
I like the brushed metal one better too alc59. I saw that tut a long time ago and just never tried it. When I saw yours done in brushed metal, I just had to give it a try with the Chipblock font.
PostPosted: Fri Oct 26, 2012 8:53 am  (#7)
Yes, but I guess the hard part would be actually drawing the shapes realistically. I don't know, maybe it is. I will have to try it...:D
PostPosted: Fri Oct 26, 2012 11:40 am  (#8)
alc59: looks fun! i'll definitely check out that tutorial :).
draconian: nice job! looks very metally with that font :).
mariawendt:
- that's what i thought too! if you try it, will you post your results and tell us what the hard parts were? i think digital origami looks a bit too much like precision work for me, but maybe it's not as bad as i think :).
PostPosted: Mon Oct 29, 2012 2:57 pm  (#9)
Yeah, I'll try it as soon as I get my laptop back from the shop. I think what I do is draw over an image first to get a feel for the thing and then do it by hand. I am leaning towards this image here (http://www.google.com/imgres?hl=en&safe ... s:20,i:237), but it may be too hard for a first try.
PostPosted: Mon Oct 29, 2012 4:07 pm  (#10)
mariawendt: naah, that's just hard enough :). i believe it's better to try something hard that you want to do rather than something simple that you just don't care about.
PostPosted: Mon Oct 29, 2012 4:25 pm  (#11)
AnMal wrote:
mariawendt: i believe it's better to try something hard that you want to do rather than something simple that you just don't care about.
ahhhhh, that is such a good thing you said. Do you care if I quote you?
PostPosted: Mon Oct 29, 2012 4:26 pm  (#12)
mariawendt: i'd be honoured, sister *lifts imaginary hat*.
PostPosted: Tue Jun 09, 2015 2:14 pm  (#13)
:clap
PostPosted: Tue Jun 09, 2015 2:15 pm  (#14)
Pretty
PostPosted: Tue Oct 16, 2018 3:26 am  (#15)
The link for this tuto doesn't work anymore :(
PostPosted: Tue Oct 16, 2018 4:52 am  (#16)
Looks like just a clever use of the "Conical" gradient shape.
PostPosted: Tue Oct 16, 2018 5:25 am  (#17)
It is a nice effect, you can still get the now defunct site using the web archive.
https://web.archive.org/web/20120504042 ... e-headings
Dumped as a pdf: attached.
I like the final comment " At this point Gimp crashed on me "
best of luck.
folderd-text.pdf [1.2 MiB]
Downloaded 429 times
PostPosted: Tue Oct 16, 2018 5:44 am  (#18)
viewtopic.php?f=9&t=14696&start=440
This link to a custom font may save you some time - see post #450
PostPosted: Tue Oct 16, 2018 6:00 am  (#19)
Thank you so much Skinnyhouse. A very realistic cut papercraft font. :bigthup :tyspin
PostPosted: Wed Oct 17, 2018 8:22 am  (#20)
Thank you for your help ! It's very interesting to see all this work done for users. Thank you for the font too. Very usefull !
