It is currently Sun Oct 11, 2026 11:34 pm
 Post subject: Lightning Weave Sig
PostPosted: Mon Nov 19, 2012 1:46 am  (#1)
Here's the tutorial I promised Esper for this lightning weave sig.
It's a bit more involved than I can fit in a forum post. I hope pdf is okay.
sig tut.pdf [1.13 MiB]
Downloaded 689 times
 Post subject: Re: Lightning Weave Sig
PostPosted: Mon Nov 19, 2012 1:54 am  (#2)
wow EK22, it seems we were both working on our tutorials and posted them almost simultaneously ;)
looks good, from a quick glance !
PostPosted: Mon Nov 19, 2012 1:59 am  (#3)
Great minds think alike. I'll go have a look at yours, from a first glance, also looks good.
PostPosted: Mon Nov 19, 2012 3:45 am  (#4)
I can't keep up with you two :runpup
PostPosted: Mon Nov 19, 2012 7:26 am  (#5)
You can do it. I have faith.
PostPosted: Mon Nov 19, 2012 7:58 am  (#6)
:lol me too Odin, the new tutes just-a keep-a-comin, BTW your puppy is going the wrong direction, no wonder you can't keep up :teeth
PostPosted: Mon Nov 19, 2012 9:42 am  (#7)
Started the tut but need to go out so kind of rushed the end as its a bit more invovled than I expected, but heres what I got anyways.
PostPosted: Mon Nov 19, 2012 1:55 pm  (#8)
Is this better? Image
PostPosted: Mon Nov 19, 2012 1:56 pm  (#9)
soooo cute. yes better.
PostPosted: Mon Nov 19, 2012 9:19 pm  (#10)
i made the lightning with the free select tool, that was easier than using a brush and then painting everything black and white
PostPosted: Mon Nov 19, 2012 9:54 pm  (#11)
I really like that one, Esper!
PostPosted: Mon Nov 19, 2012 10:46 pm  (#12)
Those both turned out nice, Esper and he4rty. It's cool to see people can actually follow my tutorial. Sort of was worried it wouldn't be too clear in places.
PostPosted: Tue Nov 20, 2012 12:57 am  (#13)
ek22: oh i have to try this! it reminds me a bit of the first gimp chat tutorial i ever posted my results to, it was a tutorial on light beams.
he4rty and esper: nice results! looks good with that background, esper.
PostPosted: Sat Nov 24, 2012 7:50 pm  (#14)
i stole some gimping time today and tried out some tuts and just played. here's one of my results - not perfect, but getting there. at least i think it is...
i didn't like filling the text with a background and i do so many bevels all the time anyway, so i replaced the bevel and pattern fil with a blur on the inside and a sort of glitter stroke - turned out to be a nightmare to weave the lighning through. i added a background and that looked a bit better. nice signature material, i think!
PostPosted: Sat Nov 24, 2012 10:11 pm  (#15)
AnMal, i like the second one but i think there is a bit too much going on
maybe reducing the lightning colors to two and/or put it behind the text without weaving through the letter would look better ?
another idea might be to make the lightning icy ?
here are two tutorials for icy text:
http://gug.criticalhit.dk/tutorials/tomcat12/
http://cbt.k090999.de/gimp_eingefroren.php
PostPosted: Sat Nov 24, 2012 10:59 pm  (#16)
I think Icy might look good with your particular background AnMal. I think Esper is on to something good here. I do like your second result though. With this particular method you'll run into difficulty because it's designed to have solid filled letters on a transparent back, if your letters aren't filled you'll run into these issues you've experienced.
PostPosted: Sun Nov 25, 2012 2:41 am  (#17)
esper: i never get enough of snow and ice ice tutorials, thanks for the tip! i don't agree there's too much going on though, i like it the way it is. it's not perfect but what i want to change about it is take away the blur and make a bevelled frame of the letters instead. that will make the weaving of the lightning more obvious. i will keep the glitter stroke, though, i have a thing for glitter as you've noticed :).
ek22: thanks. your sig is very intricate and it was tricky reproducing the result even if the tutorial is clear enough, so i will go back to the tutorial when i have time and play with it a bit more. i think you're wrong about the reason for the difficulties, though. it doesn't really make any difference whether the letters are filled or not, what makes the weaving so hard is the blur inside the letters and the fact that the lightning ray is a little too wide along the vertical dimension for these particular letters. i's like to make a new lightning ray using different solid noise settings, taking away more of the vertical noise, and then use it on a bevelled frame with a different font that gives a bit more room for play.
PostPosted: Sun Nov 25, 2012 3:27 am  (#18)
oh and some more ice textures by silver on DA
http://silver-.deviantart.com/art/Textu ... 8559&qo=65
PostPosted: Sun Nov 25, 2012 9:14 am  (#19)
I typically avoid these tutorials due to laziness ... :oops:
PostPosted: Sun Nov 25, 2012 9:45 am  (#20)
@Esper, I would like to do this tutorial. Could you please translate it? thanks
cron
