It is currently Tue Nov 24, 2026 11:24 am
 Post subject: How to make a Bevel with the Emboss Filter dd style
PostPosted: Tue Jan 22, 2013 7:29 pm  (#1)
original mini-tutorial by dd from this thread:
viewtopic.php?f=4&t=6194&start=40#p77694
dd wrote:
1 - create a new layer on top of the text layer, fill it with black
2 - go to your text layer and select > alpha to selection
3 - select > feather selection by 10
4 - go to the new layer and fill selection with white # now you have a height map on your new layer.
5 - apply emboss on the new layer
6 - go back to your text layer and alpha to selection again
7 - go to new layer, invert selection, erase selection
8 - set new layer to grain merge
Type your text on a new transparent layer.
3 - select > feather selection by 15
5 - apply emboss on the new layer (Filters -> Distorts -> Emboss)
7 - go to new layer, invert selection, erase selection (or alternatively, create a layermask from selection)
alternatively, use 'Colours' -> 'Colour To Alpha' and choose the grey with the colour-picker
to show the result better i made the black text red
 Post subject: Re: How to make a Bevel with the Emboss Script
PostPosted: Tue Jan 22, 2013 8:17 pm  (#2)
Esper pulls through with the definitive tut :clap
PostPosted: Tue Jan 22, 2013 8:24 pm  (#3)
Bookmarked!
PostPosted: Tue Jan 22, 2013 9:33 pm  (#4)
This is the type of basic tutorial I think I started with, then I added extra features and it grew and grew to a very complex script
PostPosted: Tue Jan 22, 2013 9:48 pm  (#5)
interesting to know Graechan !
how comes in most scripts highlight and shadow are two seperated "layers" ?
highlight is always Mode: Screen
and shadow on Mode: Multiply ?
 Post subject: Re: How to make a Bevel with the Emboss Filter
PostPosted: Tue Jan 22, 2013 10:23 pm  (#6)
I like that they are on separate layers, so you can tweak them separately if you wish.
PostPosted: Tue Jan 22, 2013 10:28 pm  (#7)
my thoughts exactly and you can use different contours on them too !
PostPosted: Wed Jan 23, 2013 4:46 am  (#8)
If you set the elevation on the emboss to exactly 30.2°, you won't need to do the "colour to alpha" on the gray, because at 30.2° the middle section becomes middle gray, and middle gray (#808080) is invisible in grain merge mode. x + 128 - 128 = x. (grain merge mode works by adding the colour values in the layers and substracting 128, or 0x80 from the result)
PostPosted: Wed Jan 23, 2013 7:52 am  (#9)
:tyspin Esper, again thx for tutorial!
Excelent! :bigthup
bbbbbbbbbbbImage
PostPosted: Wed Jan 23, 2013 10:28 am  (#10)
Thanks DD and thanks Esper for adding the screen shots, here is my result.
PostPosted: Wed Jan 23, 2013 10:41 am  (#11)
Nice he4rty, what a pretty shade of green.
PostPosted: Wed Jan 23, 2013 3:22 pm  (#12)
Thanks, Initialy the text was purple as the background I chose was the same colour I simply went colours>invert and thats the green that showed up.
PostPosted: Wed Jan 23, 2013 6:37 pm  (#13)
PostPosted: Fri Jan 25, 2013 10:12 pm  (#14)
Really nice Molly, like the second version.
PostPosted: Tue Feb 05, 2013 3:28 am  (#15)
I recently used this tutorial to help create a logo candidate for SFML and I thought I'd share the results of that effort. Used for all of the text and the shamrock.
Oh, and.. hello. :)
PostPosted: Tue Feb 05, 2013 4:43 am  (#16)
thats lovely cire !
how did you get such a nicely distorted text and how did you color everything so wonderful ?
stroke each letter individually with the gradient ?
you might want to add a very subtle outer glow to mask the slightly jagged edges of the text
PostPosted: Tue Feb 05, 2013 5:15 am  (#17)
Nice job Cire...and welcome to Gimp Chat
PostPosted: Tue Feb 05, 2013 8:41 am  (#18)
Oh, and.. hello. :)
Welcome to GC. I just loooove that font. :heart :heart :heart What is it called?
PostPosted: Tue Feb 05, 2013 9:22 am  (#19)
cire: hello and welcome to gimp chat! beautiful job on that logo, i like the colour scheme!
PostPosted: Tue Feb 05, 2013 7:36 pm  (#20)
Here's an image made using the Emboss filter. Then colorized with a layer above it set to grain merge. I had to use the curves on the embossed layer to get the darks and lights just right. I'll try to upload an xcf file if anyone wants to take a gander at the layer structure used.
GimpCat.xcf [4.27 MiB]
Downloaded 535 times
