It is currently Mon Nov 30, 2026 8:29 am
 Post subject: Glitter-text-tute-Molly
PostPosted: Sun Mar 03, 2013 10:00 am  (#1)
This is a very basic tutorial on how to make your text with animated glitter.
1. Create a new image 640 x 300
Note: I used these 3 teal glitters found in attachments.
2. Create your txt using this font (Janda Sparkle and Shine) found HERE
I just used this font because I like it but you can use any font you like.
3. Name your text (text#1) then duplicate twice arriving at 3 layers called text#1, text#2 and text#3. right click on #1 > alpha to selection...Leave this selection on for all 3 layers.
4. Turn the eye on in text#1 and turn the other two off. Using your first glitter pattern, drag it into your layer, OR use the bucket tool, set it to pattern in the dialogue and click whole selection.
Turn eye off layer#1
Go to layer #2 and turn on the eye...drag your second glitter into this layer...turn off eye. Go to layer#3 turn on the eye and drag the3rd glitter into this layer.
5. When you are finished the three layers, go to Filters > animation > playback. You will notice on the playback that the animation is 'jumpy'. This is caused by the white background layer at the bottom of the stack, which is not animated. Delete this layer, playback again and you will see it now runs more smoothly.
6. Side note: If you decide you would like to have a background behind your text, fill the white layer with a gradient, pattern, color or even an image.
7. Go to Filters > Animation > Combine Background and the three layers will fill behind your text. Then, delete that bottom BG layer.
(This filter can be found with Saulgoodes scripts) found HERE
Here are some more screen shots on the steps
Molly-Glitter.text.tute.pdf [344.92 KiB]
Downloaded 722 times
teal-sparkles.7z [1.43 KiB]
Downloaded 903 times
 Post subject: Re: Glitter-text-tute-Molly
PostPosted: Sun Mar 03, 2013 2:47 pm  (#2)
Thx Molly :hi5
bbbbbbbbbbbImage
PostPosted: Sun Mar 03, 2013 2:50 pm  (#3)
Wow that is cool akros. love what you did there, nice font
Thanks for doing my tute
PostPosted: Sun Mar 03, 2013 3:53 pm  (#4)
i'm really hopeless with animations, but this one looked easy enough - just used different parts of a big glitter photo and i liked the result. thanks, molly :)!
PostPosted: Sun Mar 03, 2013 4:12 pm  (#5)
Hello! I use to drag these Bling Bling glittering Gif in to my mail without any problem, but if I send a mail to my self
the Gif dont glitter when mail return back?
Late 2017 iMac Retina 4K 21,5 inch Mac OS High Sierra version 10.13.4
3,6 GHz Intel Core i7
16 GB Ram 2400 MHz DDR4
Graphic card Radeon Pro 560 4096 MB
Affinity Photo and Affinity Designers.
PostPosted: Sun Mar 03, 2013 4:19 pm  (#6)
hmmm seems strange, if it is saved as a gif, it should work. do you have a blocker set up?
Anyway, nice job on your sparkled text
PostPosted: Sun Mar 03, 2013 10:34 pm  (#7)
Great tutorial Molly.
PostPosted: Mon Mar 04, 2013 12:57 am  (#8)
Hi molly, blocking is off, but AdBlock ar activated. I dont think that matter.
PostPosted: Mon Mar 04, 2013 1:03 am  (#9)
lurifax73: you may be overestimating molly's language skills a little with that screenshot :). what browser are you using and what email client?
PostPosted: Mon Mar 04, 2013 1:31 am  (#10)
As iMacuser I run on Safari 6.0.2 and email client Comhem. I am happy with both.
PostPosted: Mon Mar 04, 2013 3:32 am  (#11)
Cute texteffect molly, the tut is now on my web-collection. :clap :paint
PostPosted: Mon Mar 04, 2013 4:05 am  (#12)
I missed this one, very nice AnMal. I like the little extra flower things you added.
PostPosted: Mon Mar 04, 2013 5:36 am  (#13)
Nice to see another tutorial from you Molly and it's a lovely effect.
PostPosted: Mon Mar 04, 2013 5:52 am  (#14)
Thank you my friend.
PostPosted: Mon Mar 04, 2013 8:57 am  (#15)
Very nice Molly, nice and neat and easy to follow. Thanks
PostPosted: Mon Mar 04, 2013 9:00 am  (#16)
:heart Thank you so much wooble. Nice job
PostPosted: Mon Mar 04, 2013 11:02 am  (#17)
lurifax73: okay, rightclick the gifs and try to open them with safari and see if that works.
wbool63: looks really cool with that background!
PostPosted: Tue Mar 05, 2013 6:59 pm  (#18)
Very nice tutorial, Molly. Love the results! :hi5
PostPosted: Tue Mar 05, 2013 9:26 pm  (#19)
very cool Font O. gives the glitter a whole new look.
PostPosted: Wed Mar 06, 2013 4:10 am  (#20)
O: that looks good! i agree with molly about the font, the stars and fireworks/flowers make it special.
