It is currently Thu Oct 15, 2026 3:12 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3  Next
 Post subject: Brushed Aluminium Texteffect with layerfx
PostPosted: Sun Mar 03, 2013 2:02 pm  (#1)
In this tutorial i will show you how to make a brushed aluminium texteffect with layerfx.
You will need the layerfx script by Jon Stipe. I recommend the python version, because it has a preview.
https://www.gimpscripts.net/2020/09/new ... x-210.html
This will NOT look the same when done with other Layer Effects scripts, like iccii or Graechan's iccii update !
You have been warned.
01. Start with a canvas 800x360px #4e4e4e
02. type your base text, i used the font 'Simplified Arabic Bold' 250px, Spacing -4
03. alpha select your text and save it to a channel for future use
04. create a new transparent layer under your text, name it 'Dropshadow', fill the selection with black, deselect and blur by 10
05. activate your base text layer and run Satin with the following values
06. activate your base text layer again and run Bevel & Emboss with the following values
For a brushed metal texture:
07. create a new layer on top of all #cccccc, name it Texture
08. apply RGB-Noise 0,2 on all channels
09. apply Linear Motion Blur → Length:25, Angle:145
this is a technique Draconian shows in this thread:
viewtopic.php?f=23&t=3750
09. apply a layermask from channel, to get rid of everything thats outside the textboundaries
10. set the mode to 'Burn' (or 'Multiply')
11. apply Levels
12. apply Contrast
13. you can also run Map -> Displace on the texture by using a copy of the saved channel, blurring by 12 and using it as the displacement map, but the effect is very subtle
14. add some Noise to the background (0,02) to make it look less clean
15. add a highlight to the background if you like
i used a radial gradient from white to transparent, dragged from the middle to the bottom, on a new transparent layer
Opacity 23% Mode: Screen
added RGB-Noise: 0,6
16. and you are done !
Version with Displace
 Post subject: Re: Brushed Aluminium Texteffect with layerfx
PostPosted: Sun Mar 03, 2013 3:35 pm  (#2)
Excellent effects !
Now just waiting Molly make the .PDF :mrgreen: :rofl
Thx Esper!
bbbbbbbbbbbImage
PostPosted: Sun Mar 03, 2013 4:26 pm  (#3)
akros, you are spoiled...here ya go!
Brushed Aluminium Texteffect with layerfx.pdf [519.69 KiB]
Downloaded 818 times
PostPosted: Sun Mar 03, 2013 4:42 pm  (#4)
:hehe
Super Molly! :hi5
That tutorial give so many results differents, just change one layer mode or another set. And all with beautiful visuals!
I could not get the same result of the tutorial, but I liked what one can get with it!
:tyspin Thank you Molly! :tyspin :bigthup
bbbbbbbbbbbImage
PostPosted: Sun Mar 03, 2013 4:59 pm  (#5)
well Akros, i hope you will post something
PostPosted: Sun Mar 03, 2013 5:40 pm  (#6)
As you wish Master!
After finishing, I played with the layers.
I ended up closing the eyes (making it invisible) layer of satin and highlight.
In Dropshadow changed the layer mode to Grain merge.
I also used another font (or need not have said that huh?)
One question I had was if the original font color should be black or white.
Well I ended up with this result
Thx Esper!
bbbbbbbbbbbImage
PostPosted: Sun Mar 03, 2013 5:44 pm  (#7)
hmmm, this is the nice shiny effect you get from the satin
i posted something similar in the Arabian Nights tutorial
i think you used HSV Noise instead of RGB, thats why your noise is all colorful
the text is in the same color as the background, thats why only the shadow makes it visible, as you can see here:
PostPosted: Sun Mar 03, 2013 5:51 pm  (#8)
akros: looks good even if it turned out completely different from the brushed aluminium. did something go wrong with the layers you turned off or did you just not like them?
mine started out as aluminium, but the surface reminded me so much of the semi-polished titanium i like using for anodized jewellery, so of course i had to "anodize" it to one of my standard colours :). i wanted to make a velvet background, but acceptable velvet texture is hard to make and i'm rather fussy about fabric so i gave it up.
PostPosted: Sun Mar 03, 2013 6:01 pm  (#9)
very nice AnMal, in knew you would make something pink :mrgreen:
the font was a very good choice too, me thinks
looks almost like karabiner text
PostPosted: Sun Mar 03, 2013 6:41 pm  (#10)
Well...
Apparently the source was to be color #4e4e4e, but I used white. :gaah
As my result was even different than expected, at the end, I decided to play with optional results. :paint
AnMal beautiful result! Actually the source was very good in that assembly, excellent choice! :jumpclap :clap :coolthup
Edited:
"create a new transparent layer under your text,"
I translated wrong. Traded under for above, and did this on the text layer. :troll
I'll redo. :scram
bbbbbbbbbbbImage
PostPosted: Sun Mar 03, 2013 7:11 pm  (#11)
akros: thank you! and now you know what went wrong the first time you will of course post a new result, right? :)
esper: tss, i'm not that predictable - i could have made aluminium paisleys instead...
PostPosted: Sun Mar 03, 2013 7:25 pm  (#12)
:yes :yes :hi5
AnMal, now was rapid! All settings were already set. :mrgreen:
In RGB Noise, not marked "Independent RGB". Before the Esper noted the excess of color, but not used "HSV Noise", just set up wrong.
Esper in bevel and emboss, in "Shadows-Surface Contour", not reported in the tutorial, so I left "Linear"
Thx guys
bbbbbbbbbbbImage
PostPosted: Sun Mar 03, 2013 7:31 pm  (#13)
it clearly says 'Linear' in the screenshot :mrgreen:
and much better result, Akros !
Thank you for doing my tutorial !
What is the name of the font ?
PostPosted: Sun Mar 03, 2013 7:37 pm  (#14)
Esper this tutorial is fantastic!!!!!!!! :clap
Just change some layers and voilá! 1001 differents results!!!
And would continue for more different results for the same tutorial!
:tyspin
bbbbbbbbbbbImage
PostPosted: Sun Mar 03, 2013 7:44 pm  (#15)
I had to give it a try with Iccii
PostPosted: Sun Mar 03, 2013 7:50 pm  (#16)
Seriously? I confess that I look and do not see .... I see only the "surface to contour to Bevel and Gloss. But not to Shadows.
But ok.
The font is: ethnocentric
bbbbbbbbbbbImage
PostPosted: Sun Mar 03, 2013 8:35 pm  (#17)
Some nice results, mine didn't turn out like i wanted, and by the time i got done trying different things (way off from the tute) i ended up with this..
I'll have to try it again
Speaking of metal, where's Drac been?
PostPosted: Sun Mar 03, 2013 9:15 pm  (#18)
im very impressed with your result, alc !!
it looks nice and clean - i especially like the background
how did you get the fading stroke ?
erasing ?
had another go, not too happy with it....
PostPosted: Sun Mar 03, 2013 9:20 pm  (#19)
Our Master Metallurgist Drac has been missed by all
PostPosted: Sun Mar 03, 2013 9:22 pm  (#20)
Drac said hes taking some time off
Graechan, i like your result, especially the reddish tint, but i think the iccii bevel is not doing the whole piece a favor
