It is currently Sun Oct 11, 2026 3:49 am
 Post subject: 3 Different Animations on 3 Separate Lines
PostPosted: Wed Mar 06, 2013 12:59 pm  (#1)
This tutorial is a continuation of my previous one found
HERE
This is a tutorial on making three lines of text with separate glitter for each line. Refer to my previous tutorial for how to use the glitter patterns and a link to Saulgoode's combine background script.
1. Start with a New Layer 600x300. Use a Font of your choice.
2. Make 3 Lines of text and make sure you space your lines with enough room to select each line with the rectangle select tool :rectsel .
3. Center your text manually like this.
4. Right click your text layer---> Lock transparency
5. Click eye next to layer to turn off and make invisible.
Double click the layer and name it #1.
I will be working with 3 sparkle files so that means we will need 3 layers.
Duplicate :dupe the text layer twice to make your 3 layers...they will be
called #1, #2 and #3.
6. Select bottom layer, alpha to selection, #1, turn on visibility-->Use the Rectangle tool to select top layer, #3 text.
Use bucket tool, OR drag your first sparkle pattern into this layer. Turn on
#2 layer and drag your second sparkle into this layer. Turn on your #3
layer and drag your 3rd sparkle into that layer.
YOUR ARE NOW FINISHED WITH YOUR TOP LAYER
7. Turn off the visibility of #2 and #3, Click layer #1 to select. With your rectangle select tool, select your middle text the same way you did with your top layer and select another sparkle pattern, group of three.
8. Now using a new set of sparkles, Select bottom layer, #1, turn on visibility-->Use the Rectangle :rectsel tool to select middle layer, #1 text.
9. Use bucket tool, OR drag your first sparkle pattern into this layer. Turn on
If your are not going to use a background, delete your bg layer. Then you are done.
If you prefer a background, fill your bg layer with whatever you want. I prefer something very plain so it won't take away from your sparkle patterns.
Run the sg-combine background, then delete bottom bg layer.
If you have any questions, please post back here to this thread.
Molly
 Post subject: Re: 3 Different Animations on 3 Separate Lines
PostPosted: Wed Mar 06, 2013 2:24 pm  (#2)
Thanks Molly, I going to try both of your tuts :)
PostPosted: Wed Mar 06, 2013 2:26 pm  (#3)
Thanks Odin, appreciate that.
PostPosted: Wed Mar 06, 2013 3:34 pm  (#4)
This looks very nice, Molly. I have not done much with animations, so I will give it a try tonight.
PostPosted: Wed Mar 06, 2013 7:46 pm  (#5)
I've done this previously using an animation merge script which takes away the shifting of layers
PostPosted: Thu Mar 07, 2013 7:40 pm  (#6)
There is a link to sg-combine background at the top of the first tute. Here it is. It also includes the overlay background.
http://gimpscripts.com/2011/10/combineo ... ackground/
I am not sure what you did wrong on the tute. After you select your line with the select tool, you put a glitter in each layer, three layers, three glitters. Then you start over with another set of glitters, a different color. then do the third line.
PostPosted: Fri Mar 08, 2013 11:13 pm  (#7)
gramg wrote:
Molly, can you tell me what font you used for this tutorial?...thanks.
Even though I'm not Molly, I do know what the font is. It's TWELVE TON GOLDFISH.
http://www.dafont.com/search.php?q=TWELVE+TON+GOLDFISH
To get the uneven characters, turn on the Caps Lock key.
PostPosted: Sat Mar 09, 2013 12:21 am  (#8)
You're welcome.
Here's my animation. Guess I can't count. Have 4 animations.
PostPosted: Sat Mar 09, 2013 2:09 am  (#9)
You did not duplicate your text layer properly, the color on the first lie of text should be the same on all 3 layers end the second line of text should have the same color on all 3 layers e.t.c. for each line of text[/align]
as in example below↓
PostPosted: Sat Mar 09, 2013 4:07 am  (#10)
"0", that is so very cool. Love your choice of glitters. thank you for doing my tute.
PostPosted: Sat Mar 09, 2013 12:52 pm  (#11)
You are doing great. woo hoo :teeth
PostPosted: Sat Mar 09, 2013 1:12 pm  (#12)
PostPosted: Sat Mar 09, 2013 1:28 pm  (#13)
Thank you alc. That teal glitter is my favorite one. love the font.
