It is currently Mon Nov 30, 2026 9:13 am
 Post subject: Create burnt wood and cookie text!
PostPosted: Sun Mar 17, 2013 3:23 pm  (#1)
Heyho!
This tutorial show you how to create realistic burnt wood and cookie text effects!
You can download the textures, backgrounds and brush-files here:
http://www.mediafire.com/?bvxz0u6pgvi9b9a
burnt wood and cookie text.pdf [4.59 MiB]
Downloaded 1057 times
 Post subject: Re: Create burnt wood and cookie text!
PostPosted: Sun Mar 17, 2013 3:31 pm  (#2)
yay, finally! i want to make cookie text!
PostPosted: Sun Mar 17, 2013 3:50 pm  (#3)
:bigthup Thank you so much Chris
PostPosted: Sun Mar 17, 2013 3:51 pm  (#4)
thanks Chris !
PostPosted: Sun Mar 17, 2013 10:53 pm  (#5)
Chris,
Thanks for another great tutorial. If I were accomplished like so many others here, I would draw a penguin in a fire hat with a hose putting water on it. Unfortunately, that is beyond my capabilities for now. :)
PostPosted: Mon Mar 18, 2013 12:45 am  (#6)
jas45: i like how you got creative there :). looks cool, but is there any way to sharpen the edges?
someone ate my "t"!
PostPosted: Mon Mar 18, 2013 4:06 am  (#7)
Oh yes...so many nice results over night! :bigthup :clap
PostPosted: Mon Mar 18, 2013 5:40 am  (#8)
My Cookies and I am not sharing...Thank you Chris for the dough :teeth
PostPosted: Mon Mar 18, 2013 11:32 am  (#9)
AnMal: Thanks. I agree that the sides need to be sharper, and the top edge should be more rounded too. I will have to work at it.
PostPosted: Tue Mar 19, 2013 3:38 pm  (#10)
I just had to make one more try at improving my 3-D look on this tutorial.
Thanks again for the tutorial, Chris F. :)
PostPosted: Tue Mar 19, 2013 3:39 pm  (#11)
yummy...great job
PostPosted: Tue Mar 19, 2013 3:41 pm  (#12)
Thanks Molly, I learned a lot doing it even though it is still not perfect.
PostPosted: Tue Mar 19, 2013 3:42 pm  (#13)
never saw a perfect cookie yet.
PostPosted: Tue Mar 19, 2013 4:08 pm  (#14)
the underside of the edges just needs a bit of curving/beveling as it looks a bit flat on the bottom edges, but it looks yummy
PostPosted: Wed Mar 20, 2013 12:30 am  (#15)
Jas45 - Looks good, made me hungry now.
PostPosted: Wed Mar 20, 2013 1:40 am  (#16)
Hi Chris F,
Thanks for this tutorial, I appreciate your efforts. :) :bigthup
fluffy bunny
PostPosted: Wed Mar 20, 2013 1:49 am  (#17)
fluffybunny - Clever idea, and love the additional smoke.
PostPosted: Wed Mar 20, 2013 3:09 am  (#18)
I luv it fluffy. You did a nice job on the smoke too...did you use a smoke brush for that?
PostPosted: Wed Mar 20, 2013 5:25 am  (#19)
Thanks for the encouragement molly :)
I used a few brushes from the Revnart Smoke collection - Revnart Smoke
I set the brush dynamics to 'Pressure Opacity' and paint the smoke using my tablet.
I then motion blur the smoke until I am happy.
fluffybunny
PostPosted: Wed Mar 20, 2013 5:35 am  (#20)
Thank you.
