It is currently Thu Nov 26, 2026 3:44 am
 Post subject: Dymo Label Text Effect
PostPosted: Wed Mar 20, 2013 1:43 am  (#1)
Was just playing around on Gimp the other day, when this effect started to emerge, so went with the flow.
So I decided I would create a tutorial for it.
Note - updated to V01 to correct an error.
Dymo Label Text Effect v01.pdf.zip [4.85 MiB]
Downloaded 784 times
 Post subject: Re: Dymo Label Text Effect
PostPosted: Wed Mar 20, 2013 2:08 am  (#2)
PostPosted: Wed Mar 20, 2013 8:23 am  (#3)
Very nice tutorial! Thanks! :bigthup
I love the grain texture!
PostPosted: Wed Mar 20, 2013 8:37 am  (#4)
Nice tute he4rty, thank you. I will get to it later on today, I hope.
PostPosted: Wed Mar 20, 2013 9:14 am  (#5)
he4rty: haha, i was wondering how you did that :). thanks for sharing!
PostPosted: Wed Mar 20, 2013 9:57 am  (#6)
Very nicely written he4rty.
PostPosted: Wed Mar 20, 2013 11:23 am  (#7)
Good one
I had trouble in step 4, adding noise to new layer, couldn't add noise to transparent layer ¿, had to duplicate the clouds and added noise to that
PostPosted: Wed Mar 20, 2013 11:23 am  (#8)
Very nice tutorial he4rty! Thank you. :yes
PostPosted: Wed Mar 20, 2013 11:33 am  (#9)
So that was what the problem was. I couldn't get the noise either. I tried adding a white layer but that didn't work. Good to know.
PostPosted: Wed Mar 20, 2013 11:38 am  (#10)
alc59 - Yes my fault forgot to mention the layer needs to be filled with grey 808080 first before running the noise filter, amended the pdf.
Nice results everyone.
PostPosted: Wed Mar 20, 2013 11:54 am  (#11)
PostPosted: Wed Mar 20, 2013 11:59 am  (#12)
Thanks for the tutorial, He4rty. I was going to ask about the Noise layer too, but I see that has been solved while I was offline.
:tyspin
PostPosted: Wed Mar 20, 2013 5:59 pm  (#13)
Mike, Jas45 - nice results.
PostPosted: Wed Mar 20, 2013 10:49 pm  (#14)
Did some labels from my dymo machine
this one is without cloud or grain layers
PostPosted: Thu Mar 21, 2013 4:39 am  (#15)
PostPosted: Thu Mar 21, 2013 7:16 am  (#16)
Great job everyone...love the gimp tools one.
Had to do one more. I don't recommend using yellow for BG, but too lazy to change it.
PostPosted: Thu Mar 21, 2013 9:38 am  (#17)
Nice work everyone, Molly suprisingly black works pretty well...
PostPosted: Thu Mar 21, 2013 9:41 am  (#18)
Ok, I had to find images to know what you meant with Dymo thing...
Now that I know, excellent result! :)
Thank you!, he4rty
PostPosted: Thu Mar 21, 2013 9:21 pm  (#19)
Some More labels for you from my script
PostPosted: Thu Mar 21, 2013 10:14 pm  (#20)
Graechan, did you make a script for this? Where?
