It is currently Mon Oct 05, 2026 9:41 am
 Post subject: Painting Noses
PostPosted: Thu Mar 28, 2013 8:16 am  (#1)
Moko expressed a desire to paint better noses so I created this PDF for anybody who has a use for it.
Painting Noses.pdf [340.34 KiB]
Downloaded 723 times
 Post subject: Re: Painting Noses
PostPosted: Thu Mar 28, 2013 9:10 am  (#2)
Very nice eris. thank you
PostPosted: Thu Mar 28, 2013 10:37 am  (#3)
:shock: :shock: :wh :drum :yr :coolguy :sun :snap :tuxy
YAY! You're my new best friend! :D
I read it, I think I'm gonna try it out later today, I'm so excite now. YAYAYAYA :D
Thank you! :D
PostPosted: Thu Mar 28, 2013 1:14 pm  (#4)
erisian: thanks for sharing, brother :)!
PostPosted: Thu Mar 28, 2013 1:34 pm  (#5)
I need help with noses..... along with everything else, thanks.
PostPosted: Thu Mar 28, 2013 2:40 pm  (#6)
I followed your directions the best I could but also added a bit of my own stuff in there...For a first attempt I think it's okay, could always be improved but you know...! xD
I only did the front-view nose since I wanted to focus better.
PostPosted: Thu Mar 28, 2013 5:39 pm  (#7)
mokonafan: nice nose :)!
PostPosted: Thu Mar 28, 2013 10:18 pm  (#8)
Erisian,
Thx very much! Excellent tuto! :tyspin
Mokonafan,
Yah! Was nice! :bigthup
bbbbbbbbbbbImage
PostPosted: Thu Mar 28, 2013 10:38 pm  (#9)
Aha thank you. xD
Couldn't have done it w/o Erisian's tutorial, though! :D
PostPosted: Fri Mar 29, 2013 12:32 am  (#10)
Thanks! I've been looking for a good nose tutorial.
PostPosted: Fri Mar 29, 2013 1:47 am  (#11)
Erisan - Thanks for the tut, Really fancy having a go at this but could somebody point me in the right direction concerning the brush set up.
So I had a go, first time in years I've actually tried drawing anthing, so not to bad although lots of room for improvement.
PostPosted: Fri Mar 29, 2013 4:21 am  (#12)
he4rty: that looks a lot like erisian's style on noses :). great job, especially as you say you haven't painted anything in years.
PostPosted: Fri Mar 29, 2013 1:36 pm  (#13)
i had to try it of course. here's my "nose job", as he4rty put it:
the flaws: the left side of the nose is too undefined. i'd say it looks ... well, ambiguous. the curving on the top isn't correct, the two curves are completely dissimilar. also the bridge of the nose on the right side looks too sharp at the top. but it was a good lesson and great practice for me.
PostPosted: Fri Mar 29, 2013 3:40 pm  (#14)
I haven't done that view yet AnMal! I like your result!
@He4rty:
I turn the opacity down on the fuzzy brush and use multiply layer mode, and make depth that way, other wise I'll use double the layers. :hehe
PostPosted: Sat Mar 30, 2013 6:18 am  (#15)
Thank you everybody - it's nice to see the results too.
Moko - a really good start and definitely 3D. Painting with a mouse isn't easy either.
he4rty - you've got the idea but use a fuzzy brush. I should have mentioned this. Also use brushes that are slightly larger than you would expect. You can use the eraser and smudge brush to fine tune the shapes if you like.
AnMal - that's an excellent nose - you've done this before haven't you.
PostPosted: Sun Mar 31, 2013 6:18 pm  (#16)
mokonafan: thank you! to be honest i took the easy way out when i tried that angle, because i know i'm better at that than at painting noses i front view.
erisian: thank you:)! but what kind of a teacher are you if you let me get away with obvious mistakes? you're supposed to say stuff like: "you got the lines under the nose all wrong! they're not placed correctly and the angle isn't right either" and "the left side of the nose is a real mess, it needs more definition and you should decide once and for all where the nose ends!"
(and i've never painted noses in this way before, i'm used to throwing in shadows and highlights in a much less systematical way, so the tutorial really was a good lesson for me!)
PostPosted: Tue Apr 02, 2013 6:22 am  (#17)
What kind of teacher am I leaving my nose scruffy and inaccurate? :)
PostPosted: Tue Apr 02, 2013 3:13 pm  (#18)
erisian: scruffy and inaccurate? oh, i get it - you're talking about the one you were born with :rofl
i'm doing everything to avoid trying the front view. i'm no good at those, tutorial or not.
PostPosted: Tue Apr 02, 2013 4:40 pm  (#19)
LOL Erisian. XD
I'm scared to do the 3/4th view it looks harder. :S
AnMal, you do your front view and I'll do the 3/4th view! :P
PostPosted: Wed Apr 03, 2013 8:00 am  (#20)
:hoh
