It is currently Mon Oct 05, 2026 4:40 pm
 Post subject: Steam-Punk Copper effect
PostPosted: Sat Apr 27, 2013 3:36 am  (#1)
You will need Graechans - Blue Ice Script
Tutorial
 Post subject: Re: Steam-Punk Copper effect
PostPosted: Sat Apr 27, 2013 3:39 am  (#2)
Very nice Rod. :bigthup :cool
I wonder if we will get a script for this one.
PostPosted: Sat Apr 27, 2013 3:45 am  (#3)
I was actually thinking of writing one for it.Pretty easy PDB steps. :hehe
PostPosted: Sat Apr 27, 2013 3:52 am  (#4)
Looks like Metal on wood or is that the font?
PostPosted: Sat Apr 27, 2013 4:00 am  (#5)
Nope the font is regular ole sans bold.
The pipeline involves Graechans blue ice script, bump mapping, color balance, and lighting effects. :)
I need to speak to Graechan first before i start.Possibly he could just add the effect to Blue Ice.
Then just rename the script to Steam-Punk-Copper or something.
PostPosted: Sat Apr 27, 2013 8:53 am  (#6)
Very nice Rod. Copper is one of my favorite things and I've tried to find good copper gradients, textures and patterns. I have a lot of gradients and a couple patterns but I've not been able to make something copper and really look like it.
PostPosted: Sat Apr 27, 2013 9:38 am  (#7)
Here you go O.Seamless copper. :bigthup
PostPosted: Sat Apr 27, 2013 9:52 am  (#8)
Thanks! Grabbed it. This is the copper look I want to be able to emulate. Like the copper in a new penny - bright, shiny, lovely copper.
PostPosted: Sat Apr 27, 2013 9:56 am  (#9)
I will see what i can do. :)
If you use noise >slur that creates a bit of a wavy effect.But you lose the seamlessness.
PostPosted: Sat Apr 27, 2013 10:00 am  (#10)
Not to worry. I've been trying for years to get the perfect copper pattern or gradient. The problem lies in the reflective surface of it.
PostPosted: Sat Apr 27, 2013 10:08 am  (#11)
This is close but i think i will add a ripple.
PostPosted: Sat Apr 27, 2013 10:20 am  (#12)
GMIC does wonders :bigthup :hehe
PostPosted: Sat Apr 27, 2013 10:26 am  (#13)
I don't think this will work. It needs a hammered look to it. :hehe
PostPosted: Sat Apr 27, 2013 10:39 am  (#14)
:lol You are going to entirely too much work, Rod. If you do a Bing search for copper, you will see all sorts of brigh, shiny copper stuff.
WB to the Staff! :hi5
PostPosted: Sat Apr 27, 2013 11:53 am  (#15)
Thank you for the welcome O. :)
Here is one more try.I think i got the shine or reflection about right. :bigthup
The seamless pattern
PostPosted: Sat Apr 27, 2013 12:19 pm  (#16)
Thanks, Rod.
I ripped off a chunk of the image here and scaled it down to bowl tut size. It still lost the nice reflection in the translation. My quest, I fear, will go on. :hoh
PostPosted: Sun Apr 28, 2013 1:00 am  (#17)
tried the text using your copper Rod but didn't get the 'shine' in the face. (ps. I used palitino lino type font)
I tried it with sans but was the same.Image
 Post subject: Re: Steam-Punk Copper effect -and tutorial
PostPosted: Sun Apr 28, 2013 6:36 am  (#18)
Just using blue ice and the pattern will not work.
You have to use blue ice with active gradient black and white default (fg to trans) bump map it to itself, color balance, and lighting effects.
blue ice settings (keep layers so you can turn off the shadow)
Color balance settings - select top layer
Lighting - select top layer
bump map settings - select top layer
Curves - select top layer
Result
You can give it a brighter or darker look with the curves tool if you wish.You can now either turn off the shadow and create a different one (because you ticked keep layers in the blue ice interface) :bigthup
I moved this to tutorials by the way. :tyspin
PostPosted: Sun Apr 28, 2013 6:48 am  (#19)
Here is the result using fg-bg gradient for active (black and white default), and an opposite curve than before.
PostPosted: Sun Apr 28, 2013 8:00 am  (#20)
Thank you Rod. Did one, following your tut.
