It is currently Thu Oct 08, 2026 5:50 pm
 Post subject: Re: Purple
PostPosted: Fri May 17, 2013 9:24 am  (#1)
conbagui wrote:
Nice font Esper, I like it. Do you have a Tut from it? :jumpclap
the font is 'Syndrome BRK' at ~300px and no, there isnt a tutorial
i couldnt really write one because the purple text is a sideeffect of my experimentations with Erisian's innard technique
and the glowing highlights are a result of that texture
here is a screenshot of the bevel values
PostPosted: Fri May 17, 2013 11:18 am  (#2)
Nice work! I think it looks really slick and should be known as the Esper effect. :hehe
PostPosted: Fri May 17, 2013 11:45 am  (#3)
Great looking text effect! :jumpclap The color is just perfect too. ;)
PostPosted: Fri May 17, 2013 12:43 pm  (#4)
Beautiful! Love the color and the shine.
PostPosted: Fri May 17, 2013 1:31 pm  (#5)
OoOoOoOoOoOoOoOoOoOo Shineyyy. Nice work it's pretty. :D
PostPosted: Fri May 17, 2013 3:53 pm  (#6)
Well done, Esper. :bigthup
I find the overall aspect of your image very agreeable for the elegant colors and the effective embossing of the letters.
PostPosted: Fri May 17, 2013 8:37 pm  (#7)
Thanks everybody !
Yes Wallace, i agree about the colour, you know who you are :hehe
Now with added tutorial on my blog:
http://gimp-science-labs.blogspot.de/20 ... orial.html
 Post subject: Re: Purple (with tutorial link)
PostPosted: Fri May 17, 2013 8:45 pm  (#8)
Excellent effect Esper. :)
PostPosted: Sat May 18, 2013 4:47 am  (#9)
esper: very unoriginal of me, but i think this looks great! and i see you wrote a tutorial after all, thanks :).
PostPosted: Sat May 18, 2013 11:54 am  (#10)
I added another screenshot on my blog, to show how one can improve the curve process
i think the "killer feature" of the effect is to make the highlight gloss up the edges
it should be a ring like shape with no fill - not too sharp and not too fuzzy
PostPosted: Sat May 18, 2013 12:36 pm  (#11)
Nice tut! :bigthup Here's how my text came out.
PostPosted: Sat May 18, 2013 5:04 pm  (#12)
wallace: that looks just perfect! not very surprising that you'd try your hand at this one :).
i've been fighting to get rid of a tension headache (too much sunlight and not enough sunglasses) before it turned into a migraine, so i've only been on the computer for a short while today. i might try this tut now, though, it's high on my gimp to-do list.
PostPosted: Sat May 18, 2013 5:25 pm  (#13)
@AnMal,
Yeah... had to give this one a go due to it's color. ;)
PostPosted: Sat May 18, 2013 6:23 pm  (#14)
it's getting ridiculously late, but here's my result - couldn't resist a change of colour :).
PostPosted: Sat May 18, 2013 7:57 pm  (#15)
Wallace, perfect execution !!!
i guess it was easier for you because its in your trademark colour ;)
AnMal, your usual high quality
i feel its getting old, saying its amazing all the time....
but what can i do ?
it is !
seems you used the attached texture i provided for the Inner Glow ?
looks good !
did you use the same texture for the gold stroke ?
if so, im surprised how extremely well it works - just like its made for that job
PostPosted: Sat May 18, 2013 9:18 pm  (#16)
@ AnMal... Nice J.O.B.!!! :bigthup
Glad you managed to crank this one out. Hope your felling better. ;)
@ Esper... Thanks Esper, I did have trouble with all the curve settings, but managed to pull it off nonetheless. :hehe
PostPosted: Sat May 18, 2013 9:58 pm  (#17)
what exactly did you find difficult ?
PostPosted: Sun May 19, 2013 12:29 am  (#18)
Well... Not knowing which layer to apply the curve to and what mode to use for the curves. The layers that I did apply the curves to, the mode was not able to be set, so that kind of through me off a bit.
In the tut, the curves mode in your images was set the 'Alpha', this mode could not be set for any of the layers in my 2.6 Gimp.
PostPosted: Sun May 19, 2013 1:15 am  (#19)
i see,
well my blogs works in a way, that i expect my readers to understand the basic tutorials i posted earlier
there is one about alpha curves - what they are and what you can do with them
you can find it here:
http://gimp-science-labs.blogspot.de/20 ... w-you.html
i posted a similar tutorial here on GC too
im not explaining that in every tutorial again - because that would take too much time
what i dont understand is, how have you been able to get the final result, if you couldnt apply any of the curves in alpha mode on your layers ?
PostPosted: Sun May 19, 2013 8:20 am  (#20)
Got a bit lost on some features as I had limited time, but hopefully I managed to recreate enough of the tutorial to make it work!
