It is currently Wed Oct 07, 2026 6:45 am
 Post subject: Adding G'MIC and MathMap to Onkels Gimp-Painter-2.8
PostPosted: Sun Jun 02, 2013 1:50 pm  (#1)
Adding MathMap - download the file below.
MathMap Plugin
To install the Mathmap filter follow these directions PRECISELY or it will not work.
Unzip the download
There are two folders in the zip
MM_Add_2_plug-ins AND
mathmap
1) mathmap MUST be placed in the gimp-painter-2.8\.gimp-2.8 folder
2) All files INSIDE the MM_Add_2_plug-ins folder MUST go in the gimp-painter-2.8\.gimp-2.8\plug-ins folder
Now restart Gimp Painter and you should have mathmap
You will find Mathmap under Filters > Generic > Mathmap
G'MIC is as simple as installing into the gimp-painter-2.8\plug-ins folder.
You will find G'MIC under Filters>G'MIC
 Post subject: Re: Adding G'MIC and MathMap to Onkels Gimp-Painter-2.8
PostPosted: Sun Jun 02, 2013 8:00 pm  (#2)
Adding MathMap Plugin-
Unzip the download
mathmap
PostPosted: Sun Jun 02, 2013 8:35 pm  (#3)
Rod did this work in the 64bit version as well
PostPosted: Sun Jun 02, 2013 8:37 pm  (#4)
I do not have 64 bit, but i imagine it would. :)
PostPosted: Mon Jun 03, 2013 2:26 am  (#5)
Well I could not get MathMap on the 64bit Painter working before but now with your files it works :jumpclap :bigthup thanks Rod
PostPosted: Mon Jun 03, 2013 11:25 am  (#6)
Your welcome. :) I am very happy it works for you.
