It is currently Sat Oct 10, 2026 5:13 pm
 Post subject: Gator text
PostPosted: Sat Jun 29, 2013 12:23 am  (#1)
typeface is called "savatage"
 Post subject: Re: Gator text
PostPosted: Sat Jun 29, 2013 3:58 am  (#2)
Looks good, Rod!
The text note is good but how...?
Is this script or a technique?
PostPosted: Sat Jun 29, 2013 4:50 am  (#3)
rod: cool! and i also wondered how?
PostPosted: Sat Jun 29, 2013 7:27 am  (#4)
Odinbc wrote:
Looks good, Rod!
You will need G'MIC - http://gmic.eu/
and GC Drop Shadow scm script - http://gimpscripts.com/2013/05/gc-shadow/
Create a new image - white bg
Create some text
Open G'MIC>Rendering>3d extrusion (set your extrusion the way you want it).I used these settings
Now do a alpha to selection on the new text layer, and create a new layer - fill the selection on the new layer with the Red Cubes 64x64 pattern)
Set that layer mode to overlay.
Copy overlay layer 2 more times.
Make the white bg layer invisible.
New from visible.
Make all layers invisible except bg and visible layer.
Select visible layer
Run Filters>light and shadow>gc dropshadow with inner glow and shadow all else default.
Go to Filters>light and Shadow>drop shadow - use defaults.
Go to colors>colorize and color how you want. :)
That's it.
XCF attached also. :bigthup
3D-text-GMIC.xcf [1.86 MiB]
Downloaded 518 times
I have actually thought about scripting this one.
Maybe. :hehe
PostPosted: Sat Jun 29, 2013 7:47 am  (#5)
Moved to text tutorials.
PostPosted: Sat Jun 29, 2013 12:14 pm  (#6)
Rod, Thanks for the tutorial :bigthup
PostPosted: Sat Jun 29, 2013 1:50 pm  (#7)
That was fun and easy. I don't know how you got some of your edges smooth without the scales. Also, after alpha to selection and filling with pattern, needs to be deselected.
Nice tutorial, Rod. :bigthup
PostPosted: Sat Jun 29, 2013 2:24 pm  (#8)
:pengy cool :bigthup
PostPosted: Sat Jun 29, 2013 8:59 pm  (#9)
To be perfectly honest i have no idea how i got that alpha effect either.
Maybe one or two of the copied pattern layers opacity setting was different?
Thanks for the tut corrections O. :bigthup
PostPosted: Sat Jun 29, 2013 10:41 pm  (#10)
Thx Rod!
These Red Cubes 64x64 pattern turned out great! First time I use the Rendering> 3D extrusion
Grateful for the tuto!
bbbbbbbbbbbImage
PostPosted: Sat Jun 29, 2013 10:43 pm  (#11)
You are all very welcome and i am glad you liked the tutorial. :)
