It is currently Thu Oct 08, 2026 2:55 am
 Post subject: A bit of Fun GEGL Mirror Filter
PostPosted: Sun Aug 04, 2013 8:56 am  (#1)
Most of you experienced Gimpers will know this but I discovered this filter only recently, because GEGL has not been used widely yet. GEGL has different filters . I urge the newer members to explore these filters. This is an example for a "tie dyed" shirt. A fashion statement of the 70's. I had several tie dyed tshirts (which I dyed myself with food dyes and salt) and tie dyed silk neck ties (which I bought).
Start with a 640 x400 canvas or larger and render with clouds plasma (filter| render| clouds| plasma and make it as gentle or busy as you like. Busy tends to have more definition with the filter.
Then go to Tools| GEGL and drop down to the mirrors filter. And play with the settings . The settings apply imediately. When you get to something pleasing, save it.
Alternatively start with a well defined (sharp contours) eg a large image of Wilbur and play around or do another plasma render and use the Distort| mosaic filter to develop a sort of honeycombed image before applying the GEGL mirror filter.
This is not a very useful filter unless you are after a mirrored or somewhat kaleidoscope effect but it is a nice filter to play with if you just want to experiment. By using the zoom slider to a minimum you can get some nice textures. I did not include this step.
Have fun and dont take it too seriously.
Cheers Wbool63
 Post subject: Re: A bit of Fun GEGL Mirror Filter
PostPosted: Sun Aug 04, 2013 10:46 am  (#2)
Interesting results.
By the way, GEGL operations often hang my GIMP, especially with some filters (Linux user). I have a good machine, so I do not attribute the problem to lack of resources. Do you have the same problem?
PostPosted: Sun Aug 04, 2013 11:25 am  (#3)
Hi YAFU , yes GEGL filters in general have a problem and this filter if I ask too much , too quickly also hangs in my Linux Mint14 (X64, Gimp2.8) and also hangs in my Win 7 (x64, Gimp2.6.11). GEGL is not yet capable of reliable usage. Resource is not a problem! I run a I7 3770K cpu with 16G ram.
PostPosted: Sun Aug 04, 2013 12:34 pm  (#4)
Far out! :)
PostPosted: Sun Aug 04, 2013 4:23 pm  (#5)
Nice results wbool. I like the stained glass honeycomb.
