It is currently Mon Oct 05, 2026 4:41 pm
 Post subject: Re: Let's Draw Anime Using GimP!
PostPosted: Sun Oct 27, 2013 12:52 am  (#1)
You...should teach me how to draw.
PostPosted: Sun Oct 27, 2013 2:02 am  (#2)
Excellent work and thanks for the tutorial.
 Post subject: ~
PostPosted: Sun Oct 27, 2013 3:34 am  (#3)
PostPosted: Sun Oct 27, 2013 3:53 am  (#4)
All/any part. I am suck with a pen.
PostPosted: Sun Oct 27, 2013 6:48 am  (#5)
Zeo wrote:
There are not many anime tutorial involving GimP, so I decide to make one. Yippie!(^_O)
GimP version used in this tutorial is 2.8.6 (^_^)
1. Let's begin with sketch. I do sketch manually on paper, so nothing special here.
2. Scan and adjust it using GimP. I edit some proportion, as in paper sketch I lack space.
3. Then doing lineart , in GREYSCALE mode (not RGB), double the sketch size.
Here, my sketch is sized 7000 px, for lineart only, later for coloring I usually resize the image about 3700 - 4000 px.
4. Usually I drew hair on different layer than body.
5. Then drew body and... the rest...
6. Note that I re-adjust the front and back girl proportion here. After finish, we came to coloring proccess. Save (or 'export'?) your image (PNG is better due transparency. In JPG you must do "Color to Alpha" before able to color.)
7. As said before, I resize finished lineart to 4000 px height large, and adjust lineart to make it darker.
8. Then on different layer is for base color fill...
9. This maybe take long, especially in hair selection. Good for train your patience... (^_^)
Free selection is the best. But in other case, fuzzy select work best-> 'Select'>'Grow' to make the selection more smooth.
10. I am not a fan of 'quick mask' or masking. For selection I prefer use 'select similiar color' tools on different layer, like this:
The '1' layer is
The '2' layer is
11. So, for example I use 'select similiar color' tools on '2' layer and paint in 'rush#2' layer. I keep '2' layer LOCKED, same for '1' layer and 'g86la.png' layer (it's lineart layer as show in the picture, name is random, don't bother thinking about it.)
12. And it's the brush setting I used... You can adjust it as your liking, of course.
13. So it's finished... For character only. Of course it's finished if you don't intend to make background.(O_o)
14. Then finally background... Yeah, I made a new image here.
15. Insert your finished image on step 13 (By simply paste or drag the image.)
16. Background is easy... I use Gimp 2.8 default 'vegetation' brush preset here.
17. You can add more layer for something else as you like, freedom is freedom. For example you can use flower brush for some effect....
18. Then we're done!
It took about 8 hour to made, and the longest is lineart, took about 3 hours. (Because technically I made 5 pictures all-in-one, so I think it's quite reasonable to take that long. And I'm barely just switch from GimPainter 2.6.7 to Gimp 2.8...)
P.S How's my explanation style? Is it good? Or it is kinda bossy? :hehe
Wow that is great drawing Zeo. thank you for sharing.
PostPosted: Sun Oct 27, 2013 7:00 am  (#6)
Awesome sketch and even more awesome result! Thanks for sharing your techniques :D
PostPosted: Sun Oct 27, 2013 7:02 am  (#7)
Thanks for that Zeo. The tutorial is fine and not at all "bossy" and your artwork is outstanding!
PostPosted: Sun Oct 27, 2013 1:56 pm  (#8)
zeo: i love it when we get to see how you painters and drawers work, more tutorials like this! i found the colouring part a little confusing, though - for example, when you say layer 2 is locked, do you mean alpha locked?
anyway, thanks for sharing the tutorial and your anime work is just lovely.
 Post subject: ~
PostPosted: Mon Oct 28, 2013 1:02 pm  (#9)
PostPosted: Mon Oct 28, 2013 1:03 pm  (#10)
Nice!
PostPosted: Mon Oct 28, 2013 1:26 pm  (#11)
@Mokonafan: Thanks! :ninja
@AnMal:
I hope picture will explain better, you are right, I'm not clearly explain it before...
This is what will be seen if I disabled all layer... :hehe
This is 'rush #2' layer...
This is '2' layer...
I usually use 'by color select' (select region of similiar color) tools on '2' layer, and... paint it only on 'rush #2' layer, so '2' layer is keep clean... 'Lock pixels' '2' layer to not damage it... :hehe
PostPosted: Sun Nov 17, 2013 2:16 pm  (#12)
:pengy :pengy :pengy
So manly... :hehe
I am back using my old GimPainter 2.6.7 not like this tutorial advise... Now I gotta go... :ninja
PostPosted: Sun Nov 17, 2013 2:36 pm  (#13)
Those are so sweet and well done, thanks for sharing
PostPosted: Sun Nov 17, 2013 4:04 pm  (#14)
Nice work! :3
PostPosted: Sun Nov 17, 2013 4:16 pm  (#15)
Zeo - Amazing work.
PostPosted: Sun Nov 17, 2013 5:36 pm  (#16)
So manly... :hehe
This is a really beautiful image.
PostPosted: Tue Nov 19, 2013 8:40 pm  (#17)
Hallo Zeo, I wish could sketch from making a Lineart out far way. Ok I try but lines look not so good.
Andrew
PostPosted: Wed Nov 20, 2013 6:17 am  (#18)
Andrew
Let's see... Most people said that Paint Tool SAI is good for make lineart because it has line smoothing feature, but I am not used with this software, and it's not free, too... :oops:
Alternatively, you can always doing lineart traditionally by pen and paper... :ninja
PostPosted: Wed Nov 20, 2013 11:34 am  (#19)
If you go the pen and paper route, if you have a scanner use the black and white setting in the program you use to scan not grey-scale.
PostPosted: Wed Nov 20, 2013 1:03 pm  (#20)
Hallo Zeo, I do, I have only scanner no graphic tablet. My Inking in Gimp look not so smooth. :)
Andrew
