It is currently Wed Oct 07, 2026 9:17 pm
 Post subject: Multi Replicate 3D effect
PostPosted: Fri Nov 29, 2013 5:41 am  (#1)
Gino's Multi Replicate Effects filterworks really great for unique sharp 3D effects if set properly. Here is one way and i also attached the GIMP workspace file (XCF).
First download the SCM file and place in your "Scripts" directory.
1) Open GIMP or if GIMP is already opened go to Filters>Script-Fu>Refresh Scripts.and create a new document File>New - 640x400, white bg color
2) Go ahead and create your text layer using the text tool in the GIMP toolbox :text
3) Right click the new text layer and select the option "Layer to Image Size"
4) Making sure the text layer is still selected go to Edit>Multi-Replicate to open the filter.
5) Put in these settings (image example)
Select OK and let the filter run.
6)The filter will place all layers into a group folder for you. select the TOP layer in the group and right click it and select the option "Alpha To Selection".
7) Open the fg color selector dialog by clicking it in the toolbox :fg2bg
8) Select any color other than white.
9) Go to Edit>Fill with FG Color
Results
Just a rough example of the final result. You could also use pattern or gradient fills and add a shadow or lighting effects. have fun! :) :bigthup
Thanks for checking out the tutorial.
3DWithMultiReplicateFinalResult_RD.xcf [278.09 KiB]
Downloaded 382 times
 Post subject: Re: Multi Replicate 3D effect
PostPosted: Fri Nov 29, 2013 6:24 am  (#2)
nice to hear GinoD updated the script !
PostPosted: Fri Nov 29, 2013 11:17 am  (#3)
Thanks for the tutorial.
PostPosted: Fri Nov 29, 2013 1:13 pm  (#4)
I downloaded the script, but I can't locate it in gimp. what category is it under?
PostPosted: Fri Nov 29, 2013 1:51 pm  (#5)
viewtopic.php?f=8&t=9118&p=117888&hilit=how+to+find#p117888
PostPosted: Fri Nov 29, 2013 3:01 pm  (#6)
edit/multirepricate
PostPosted: Fri Nov 29, 2013 4:41 pm  (#7)
Thank you, Rod. :)
Very nice of you to share this effective tutorial by featuring and involving my script.
PostPosted: Fri Nov 29, 2013 7:00 pm  (#8)
edit/multirepricate
Thanks, Molly. I located it. :)
PostPosted: Fri Nov 29, 2013 7:35 pm  (#9)
Rod your example of using multi-replicate was better than my disappearing underwear one this is defineatly a must have and learn to use script from Gino D
PostPosted: Sat Nov 30, 2013 7:20 am  (#10)
Thanks everyone. It needs some smoothing but you can get very nice 3D effects from this filter. Thank you Gino. :)
