It is currently Sun Oct 11, 2026 5:22 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: Tribal Art
PostPosted: Mon Dec 09, 2013 1:29 pm  (#1)
In this tutorial, I will show you how to create some glowing tribal art in a few simple steps. This tutorial is based on similar techniques described in this Photoshop (PS) tutorial: http://www.tutorialwiz.com/metallic_background/ However, because GIMP's Wave Plugin does not function exactly like the one for PS, I created a script which we will use to in our artwork.
This tutorial is pretty easy and assumes the user is familiar with basic tools, such as changing colors, using brushes, changing layer modes, etc. However, if I'm not clear with my information, please feel free to ask.
Here's an example of the tribal art we will be creating:
Here's the script. It can be found under Script-Fu/Fencepost/Render/Metallic/Ripple Texture3...
Let's begin!
Step 1
Create a new black image of the desired background size. I'm using a 300 X 300, but you use whatever you want.
Step 2
Grab a brush and paint on your image in dots, lines, or even symbols. I like using whites and grays to provide depth. Even try different brush sizes. Here's mine. NOTE: I originally hosted this on GIMPER.net and I used their name in the image below. :)
Step 3
Go to Script-Fu/Fencepost/Render/Metallic/Ripple Texture3...... and the following dialog will appear:
I'm going to use the default settings, but feel free to experiment. After you've picked your settings, click OK. Here's my result....
Step 4
Duplicate this layer, set its layer mode to Lighten Only
And flip the layer horizontally (Layer > Transform > Flip Horizontally). You can flip it vertically, but we'll need to flip again in just a minute and, if you flipped vertically this time, you'll need to flip horizontally then.
Here's the result with the layer flipped and set to Lighten Only.
Step 5
With the upper layer still active, merge both layers together (Layer > Merge Down). You should now only have 1 layer.
Step 6
Duplicate the layer and, like before, set its mode to Lighten Only and flip it vertically (Layer > Transform > Flip Vertically). In Step 4, if you flipped your layer vertically then, you need to do this one horizontally. Merge these 2 layers together (Layer > Merge Down). Here's the result:
Step 7
Duplicate this layer and blur the duplicate layer a bit (Filters > Blur > Gaussian Blur...). I'm using 15 X 15.
The upper layer will now be blurred. Set its blend mode to something that makes it glow above the bottom layer; I'm using Screen.
Step 8
One last time, merge the two layers together (Layer > Merge Down)
Step 9
Color your image using one of GIMP's color tools. I'm using the default Colorize settings (Color > Colorize...)
Well, that was easy! Hope you learned something new and enjoyed making tribal art. Make sure you show me your results and, if you need help, feel free to post your questions here.
Cheers!
Art
 Post subject: Re: Tribal Art
PostPosted: Mon Dec 09, 2013 1:37 pm  (#2)
Cool FP, got the filter copied into my scripts, thank you. looks like a nice tute, got it marked.
fp-script-fu-ripple-texture.tar.gz [1.18 KiB]
Downloaded 441 times
PostPosted: Mon Dec 09, 2013 2:33 pm  (#3)
And it all began with a few scribbles, who would have known.
PostPosted: Mon Dec 09, 2013 2:45 pm  (#4)
wooo! nice avatar, makes me dizzy though.
PostPosted: Mon Dec 09, 2013 3:08 pm  (#5)
Looks like a fun tute FP.
PostPosted: Mon Dec 09, 2013 3:15 pm  (#6)
I am going to do that one tonight.
PostPosted: Mon Dec 09, 2013 3:29 pm  (#7)
Have fun and figure out interesting ways to make it your own!
PostPosted: Mon Dec 09, 2013 3:39 pm  (#8)
Couldn't wait, will do it again after supper, thanks for sharingFP
My filter dialogue was different and I didn't get the blurring when I ran the script. I might have made my text too large to cause that whatever it is at the top.
PostPosted: Mon Dec 09, 2013 3:46 pm  (#9)
This .scm file has a comma where a period/dot should be. The name of the file looks like this... (fp-script-fu-ripple-texture,scm).
Was this done on purpose.
PostPosted: Mon Dec 09, 2013 5:39 pm  (#10)
fencepost: fun, fun, fun :)! i'm doing this as soon as i have time to do tutorials again.
molly: nice result!
PostPosted: Mon Dec 09, 2013 6:36 pm  (#11)
PostPosted: Fri Sep 12, 2014 4:13 pm  (#12)
Thank you FencePost for this nice tutorial!
PostPosted: Fri Sep 12, 2014 5:48 pm  (#13)
I can't get gimp to load this script. I'm on Windows 7 and gimp 2.8.10. Any help is greatly appreciated. I copied and saved the script as an .scm file and dropped it into the scripts folder as suggested, but it's not showing up in the list under render or anywhere .
PostPosted: Fri Sep 12, 2014 6:42 pm  (#14)
I believe an updated version of that script is here.
http://gimpscripts.com/2013/12/metallic-ripple/
The one pasted into this thread is registered as ripple-texture and the one on GS is registered as ripple-texture3.
PostPosted: Fri Sep 12, 2014 7:00 pm  (#15)
Thanks Tux
PostPosted: Fri Sep 12, 2014 7:03 pm  (#16)
Thanks! I'll go give that a shot right now. Meanwhile, this is what I did without the script, using only the built in ripple filter and some rodilius and ani-smoothing. Incandescent gradient for color.
PostPosted: Fri Sep 12, 2014 8:02 pm  (#17)
Looks cool, ek22. :2thup
The tutorial has been updated to use the latest script.
PostPosted: Fri Sep 12, 2014 11:39 pm  (#18)
Cool, I installed it and am having some fun with it, i'll post some results here later.
PostPosted: Sat Sep 13, 2014 3:48 pm  (#19)
Here is a pdf if anyone wants it.
FP-Tribal tute.pdf [444.17 KiB]
Downloaded 179 times
PostPosted: Sat Sep 13, 2014 4:41 pm  (#20)
I anyone having any problem with fp-metalic ripple? I have downloaded it 3 times and installed it in my Molly > scripts folder and it won't show up anywhere, It doesn't acknowlege it at all.
