It is currently Sun Oct 11, 2026 12:58 am
 Post subject: Followed a PS Tut using Gimp
PostPosted: Fri Jan 31, 2014 12:58 pm  (#1)
I really wanted to try a few PS tuts to see if I could sort of replicate it using Gimp. This was my first and, although it's not exactly right on it came pretty close.
McGimp 2.8.14
G'mic 1.6.5
 Post subject: Re: Followed a PS Tut using Gimp
PostPosted: Fri Jan 31, 2014 1:15 pm  (#2)
Nice work there, Dalia. You got a nice textured look there and the embroidery on the word looks convincing. PS tuts can be a pain to convert sometimes but when they work the results are usually pretty good.
DeviantArt gallery
PostPosted: Fri Jan 31, 2014 1:26 pm  (#3)
I agree with Caz. You've done a very nice job. I like the blurred background as it allows the focal point to standout even more. Texturing is quite nice. Maybe you should write a tutorial? ;)
PostPosted: Fri Jan 31, 2014 1:29 pm  (#4)
That's a beauty, Dalia.
PostPosted: Fri Jan 31, 2014 1:40 pm  (#5)
Lovely work Dalia
PostPosted: Fri Jan 31, 2014 4:30 pm  (#6)
That is really beautiful. I love the felt look. Kudo's
PostPosted: Fri Jan 31, 2014 4:50 pm  (#7)
Thank you everyone. The texture on the word was actually a fiber"ish" pattern supplied that I couldn't convert so I did a quick search for something comparable.
As for a tutorial/converting someone else's tutorial (if it's allowed), I could try?
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Fri Jan 31, 2014 4:55 pm  (#8)
People have in the past adapted PS tutorials and posted their tutorials here so it should be OK.
PostPosted: Fri Jan 31, 2014 5:11 pm  (#9)
dalia: that's soooo pretty! well done on that - it's not easy to follow ps tuts since gimp does things differently, but your result looks good anyway.
PostPosted: Fri Jan 31, 2014 6:27 pm  (#10)
This looks very good and yes you can create a tutorial if you like and post it here. If you feel better you can add that you got the tutorial idea from a PS tut and give a link. Or you don't have to it's up to you.
On another note as far as i know an isn extension is for a windows install file. What is a isn pattern file and what opens it? Perhaps a script could be written to convert isn to jpg or png.
PostPosted: Fri Jan 31, 2014 9:34 pm  (#11)
Thank you Erisian, AnMal, Rod and conbagui.
Rod, my apologies, I meant to write fiber"ish" but auto correct changed it and I didn't notice. It was a PS pattern that I couldn't convert.
conbagui, I like them too - I've learned some really nice workarounds from you so, thank you!
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Sat Feb 01, 2014 6:33 am  (#12)
Dalia, all tutorials are very welcome. Make an effort, please.
