It is currently Sat Nov 21, 2026 2:48 am
 Post subject: Small Dot Pattern
PostPosted: Sat Apr 12, 2014 4:50 pm  (#1)
There's probably and easier way of doing this.
Sorry there's no sound, and that it goes along pretty fast.
 Post subject: Re: Small Dot Pattern
PostPosted: Sat Apr 12, 2014 4:58 pm  (#2)
Wow that was in high speed. I don't remember doing the dupes though. Anyway, thanks Wallace
I did some and what fun it is.
PostPosted: Sat Apr 12, 2014 5:03 pm  (#3)
Looks great Molly! :bigthup
I duplicated the layer because it was very small. There may be another way to make this kind of small 8x8 dot pattern, but I haven't found a way yet.
PostPosted: Sat Apr 12, 2014 6:15 pm  (#4)
I had to do another cuz I am hooked.
PostPosted: Sat Apr 12, 2014 6:37 pm  (#5)
:kpix
You can even do it like this.
PostPosted: Sat Apr 12, 2014 6:42 pm  (#6)
How can two squares possibly make a thousand little dots.
PostPosted: Sat Apr 12, 2014 6:49 pm  (#7)
Try it and see. :mrgreen: Just don't have snap to guides or canvas edge checked.
The smallest I've went so far was a 6x6 canvas, using the pencil at size 1.
PostPosted: Sat Apr 12, 2014 7:19 pm  (#8)
I did have both those checked and came out with this.
What does unchecking them do?
PostPosted: Sat Apr 12, 2014 7:34 pm  (#9)
Unchecking them give you more control, so that your brush or pencil does not snap to the guide or canvas edge.
That looks good Molly. :bigthup I see that you added a drop-shadow too.
PostPosted: Sun Apr 13, 2014 5:26 am  (#10)
Thanks Wallace
PostPosted: Sun Apr 13, 2014 5:40 am  (#11)
Thanks, Molly, but my heart is broken.
PostPosted: Sun Apr 13, 2014 5:51 am  (#12)
Sorry about that, I guess I can't fix that.
PostPosted: Sun Apr 13, 2014 10:15 am  (#13)
Is this what you are looking for Carlos?
PostPosted: Sun Apr 13, 2014 11:43 am  (#14)
You forgot the dots Molly. :hehe
PostPosted: Sun Apr 13, 2014 11:47 am  (#15)
You put them on, my eyes are full of dots.
PostPosted: Sun Apr 13, 2014 11:53 am  (#16)
:rofl
PostPosted: Mon Apr 14, 2014 5:17 am  (#17)
Thank you, Molly. I'll save the picture in my treasure chest. Still lack a heart exploding.
