It is currently Tue Nov 10, 2026 7:17 am
Post new topic Reply to topic  [ 231 posts ]  Go to page 1, 2, 3, 4, 5 ... 12  Next
 Post subject: How I Create BRL Images With Gimp (Bevel Reflect)
PostPosted: Wed Dec 03, 2014 6:44 pm  (#1)
This only a basic video tutorial. Feel free to ask any questions you might have about this technique.
Here's a "real time" YoutTube video link to the "nearly" completed image shown in this tutorial, created using the BRL plugin.
https://www.youtube.com/watch?v=R6OUGozLhhE
 Post subject: Re: How I Create BRL Images With Gimp
PostPosted: Wed Dec 03, 2014 8:17 pm  (#2)
Cool Wallace, thank you. and hey what a nice voice you have. :yes
PostPosted: Wed Dec 03, 2014 8:32 pm  (#3)
Thanks Molly, No problem.
Some folks might have a few questions about this, I'm willing and prepared to answer all of them. ;)
PostPosted: Wed Dec 03, 2014 9:08 pm  (#4)
Very good instructions, I can't wait to get the chance to try it out.
PostPosted: Wed Dec 03, 2014 9:14 pm  (#5)
Okay, sweet! :bigthup
Good luck 2-ton, and if you have any questions please ask them.
I'm soon, going to make a video of the completed image used for this tutorial.
Stay tuned! ;)
PostPosted: Wed Dec 03, 2014 10:16 pm  (#6)
Odd, there is no reply box for this thread, I have to hit quote the eliminate the quote in order to reply. My computer must be having a bad day. I made time to try out a very simple brl, and tried out different bevel types. The outlining came out less than nice, but I got the brl part, so all is good.
PostPosted: Wed Dec 03, 2014 10:34 pm  (#7)
That is odd... :puzzled
That looks good. Try to make the colors you use contrast with each other. Often changing the darker color can make a lot of difference in the BRL results.
PostPosted: Thu Dec 04, 2014 5:38 am  (#8)
Thank you for the tutorial on this. I tried a couple of times but didn't have much luck, now maybe I will :)
PostPosted: Thu Dec 04, 2014 9:22 am  (#9)
Cool! Good luck. :bigthup
PostPosted: Thu Dec 04, 2014 9:44 am  (#10)
Wallace the technique you use is much like the same thing that I do to create height maps. I'm wondering if you could get by without doing all the duplicates and merging them to fix edges if you were to simply select all the areas using the Fuzzy Select tool with anti aliasing turned off. Also it sure would be nice if the resulting fill could be rounded off to create more rounded looking brls. When I make rounded stuff I often use a rounded gradient instead of just the Foreground to Background. I've attached a round gradient. I suppose you could change the colors after choosing it.
File comment: Rounded Off Gradient
01RoundHalf.ggr [141 Bytes]
Downloaded 695 times
PostPosted: Thu Dec 04, 2014 10:42 am  (#11)
The lines are only 1 maybe 2 pixels wide. The issue occurs when BRL does it's smoothing. I guess I could turn down the smoothing a bit.
PostPosted: Thu Dec 04, 2014 11:09 am  (#12)
Another practice, tried using slightly different shades of green in each section. Remind me to not use huge pictures to work on, it takes my little old lappie forever to run scripts.
PostPosted: Thu Dec 04, 2014 11:30 am  (#13)
That look really good 2-ton, nicely done. :jumpclap
PostPosted: Thu Dec 04, 2014 11:41 am  (#14)
Very nice 2-ton. good job
PostPosted: Thu Dec 04, 2014 3:04 pm  (#15)
Now, can anyone tell me why this particular doesn't show a reply box for me? I still have to hit quote in order to post. The rest of the site works fine. :hoh
PostPosted: Thu Dec 04, 2014 3:09 pm  (#16)
That's a good question 2-ton, of which I have no answer to.
PostPosted: Thu Dec 04, 2014 3:11 pm  (#17)
Quick reply was not enabled in this forum. I'm not sure why. I have now enabled it.
By the way, cool tutorial and nice results!
PostPosted: Thu Dec 04, 2014 3:13 pm  (#18)
Thanks, Tux.
PostPosted: Thu Dec 04, 2014 3:20 pm  (#19)
Thank you Tux. :bigthup
PostPosted: Thu Dec 04, 2014 4:35 pm  (#20)
By jove, I think I've got it. The basics, anyway, thanks to the clear tutorial! I also fiddled around with different ways of hiding the areas that brl misses, gaussian blur, painting a lower layer, enlarging a selection and bucket filling in a lower layer. Many ways to skin a cat, as Lyle likes to say. As for turning photos into brl-ready pics, that's for another time.
